Does anyone know where the correct version of OpenVPN can be found ?
Just install with “apt-get install openvpn”. That will give you the latest and it will be updated in the future
If you try and install OpenVPN on OSMC, you get the following error:
osmc@osmc:~$ sudo apt-get install openvpn
Reading package lists… Done
Building dependency tree
E: Unable to locate package openvpn
Ive had a google search, but nothing yet. Any ideas on how to point OSMC at OpenVPN?
You need to do a ‘sudo apt-get update’ first btw, to retrieve the latest package list
Hi, Thanks OpenVPN installed ok but did you know there are several 404 errors when updating: - 404 Not Found [IP: 5.153.225.206 80]
