I have a working RPI4 with OSMC running KODI - perfect… but I want to back it up easily and run on USB… So I installed rpi-clone (which needed GIT etc)… I ran rpi-clone to clone to USB exactly as I would do on PI-OS - nothing - failure.
SO I took the clone out of the USB and put it into the SD socket - PERFECT.
On checking it seems that the clone worked but OSBC /boot/cmdline.txt wants to see the file system in mmcblk0 P2 i.e. root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp4
Whereas on an RPI normally in PIOS that line says: dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=7d3d6497-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
So I tried replacing the root bit of that line: r
oot=/dev/mmcblk0p2 with
root=PARTUUID=223d6497-02 (thats not the right number) the actual PARTUUID I got from: blkid
So that new version works in the SD slot but not in the USB socket.
If I do the same on RPI4 with PI OS and predecessors - it will work in the SD slot or USB (for SSD, USB stick etc)
Any ideas?
Regards Peter Scargill
