OSMC 5ghz Dongle dropping connection overnight
On a Pi3, fresh install. Configured and working connection for most of the day without issue. Iperf speeds of 118Mbps consistently but every morning when I try to ssh into it the connection is dead. Using a cron job to ping the network and restart if it receives a null response temporarily at the moment. Is anyone else having a similar issue with the wifi dropping with the above OSMC dongle? Haven’t run logs but I may have to debug what’s going wrong here.
I’m using the OSMC power supply that I just purchased so I don’t think it’s power related.
Nothing obvious that I can think of.
What does My OSMC show when you have no connection?
I’m not sure as the cron job keeps the wifi alive at the moment. I’ll do some testing to see what I can dig up.
