I was just wandering if the OSMC Powered Hub provides the same stable 2.5A and 5V as the OSMC Pi Power Supply, as its specifications are not listed on the store?
Thanks.
Thanks.
The PSU is 2A for the hub. This is listed on the Store.
We recommend powering the Pi with a dedicated PSU. The hub is for those attaching peripherals that will from the extra power, such as USB HDDs
Thanks. Does the Pi Power supply on the store guarantee a good steady 5V to my Pi?
Yes, it was designed specifically to supply steady power to a Pi.
Absolutely. It will come with our OSMC guarantee too.
