Hi all,
I spent some time trying to figure out how to use hostapd in bridge mode with nfs root on osmc alpha 4. The problem is that once you add eth0 to the bridge you loose nfs.
Well, after some tests, this seems to work:
br="br0"
dev="eth0"
wlan="wlan0"
# find the IPs on $dev and the default route
ip4=$(ip addr show dev $dev | sed -e "s/ \+/ /g" -e "s/^ //g" | grep "^inet " | cut -d ' ' -f 2)
ip6=$(ip addr show dev $dev | sed -e "s/ \+/ /g" -e "s/^ //g" | grep "^inet6 " | cut -d ' ' -f 2)
rt=$(ip route show | sed -e "s/ \+/ /g" -e "s/^ //g" | grep ^default | grep " dev $dev")
if [ -z "$ip4" -a -z "$ip6" ]
then
echo >&2 "Cannot find either IPv4 or IPv6 IP on eth0."
exit 1
fi
echo "Adding the $br bridge..."
ip link add $br type bridge || exit 1
for ip in $ip4
do
echo "Adding IPv4 IP $ip to the $br bridge..."
ip -4 addr add $ip dev $br || exit 1
done
for ip in $ip6
do
echo "Adding IPv6 IP $ip to the $br bridge..."
ip -6 addr add $ip dev $br || exit 1
done
echo "Bringing the $br bridge UP..."
ip link set dev $br up || exit 1
echo "Adding $dev to the $br bridge..."
ip link set $dev master $br || exit 1
for ip in $ip4
do
echo "Deleting IPv4 IP $ip from $dev..."
ip -4 addr del $ip dev $dev
done
for ip in $ip6
do
echo "Deleting IPv6 IP $ip from $dev..."
ip -6 addr del $ip dev $dev
done
if [ ! -z "$rt" ]
then
rt=$(echo " $rt " | sed "s/ dev $dev / dev $br /g")
echo "Adding default gateway: $rt..."
ip route add $rt || ip route replace $rt
fi
ip link set $wlan master $br
The script uses the linux disk cache to execute the ip
commands after ip link set $dev master $br
. The nfs is actually lost after this command, but the next ones are executed without any disk access and restore it.
Ideally, it should be done with connman. However I couldn’t find any information for connman bridge configuration. It is supposed to support tethering, but I couldn’t make it work.
Anyway, I start the above script from rc.local with a delay of 150 seconds (so after the Pi has been booted and kodi has been started).
