Need help my Motion
Aug 28 09:13:10 osmc motion[632]: [1] [NTC] [VID] v4l2_get_capability: - VIDEO_CAPTURE
Aug 28 09:13:10 osmc motion[632]: [1] [NTC] [VID] v4l2_get_capability: - STREAMING
Aug 28 09:13:10 osmc motion[632]: [1] [ERR] [VID] v4l2_select_input: Unable to query input 8. VIDIOC_ENUMINPUT, if you use a WEBCAM change input value in conf by -1:
Aug 28 09:13:10 osmc motion[632]: [1] [NTC] [VID] vid_v4lx_start: Using V4L1
Aug 28 09:13:10 osmc motion[632]: [1] [ERR] [ALL] motion_loop: Video device fatal error - Closing video device
Aug 28 09:13:10 osmc motion[632]: [1] [NTC] [VID] vid_close: Closing video device /dev/video0
Aug 28 09:13:20 osmc motion[632]: [1] [WRN] [ALL] motion_loop: Retrying until successful connection with camera
Aug 28 09:13:20 osmc motion[632]: [1] [NTC] [VID] vid_v4lx_start: Using videodevice /dev/video0 and input 8
Aug 28 09:13:20 osmc kernel: usb 1-1.4.1: reset high-speed USB device number 6 using dwc_otg
Aug 28 09:13:20 osmc motion[632]: [1] [NTC] [VID] v4l2_get_capability:
cap.driver: “uvcvideo”
cap.card: “Webcam C170”
cap.bus_info: “usb-bcm2708_usb-1.4.1”
cap.capabilities=0x84200001
my lsusb:
root@osmc:~# lsusb
Bus 001 Device 008: ID 046d:082b Logitech, Inc.
Bus 001 Device 004: ID 0bc7:0006 X10 Wireless Technology, Inc. Wireless Transceiver (ACPI-compliant)
Bus 001 Device 007: ID 048d:9006 Integrated Technology Express, Inc. IT9135 BDA Afatech DVB-T HDTV Dongle
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
root@osmc:~#
my lsmod:
root@osmc:~# lsmod
Module Size Used by
rc_it913x_v1 1317 0
it913x 4604 2
af9033 33299 2
dvb_usb_af9035 22694 2
dvb_usb_v2 17184 1 dvb_usb_af9035
dvb_core 104593 1 dvb_usb_v2
8021q 21366 0
garp 7422 1 8021q
stp 2187 1 garp
llc 5891 2 stp,garp
binfmt_misc 7326 1
uinput 9657 1
snd_usb_audio 152627 0
snd_hwdep 6492 1 snd_usb_audio
uvcvideo 84025 0
evdev 11534 12
snd_usbmidi_lib 26571 1 snd_usb_audio
videobuf2_vmalloc 6146 1 uvcvideo
videobuf2_memops 2609 1 videobuf2_vmalloc
snd_rawmidi 24035 1 snd_usbmidi_lib
videobuf2_core 57525 1 uvcvideo
v4l2_common 6434 1 videobuf2_core
snd_seq_device 5328 1 snd_rawmidi
rc_medion_x10_or2x 1280 0
snd_soc_wm8804_i2c 1862 0
snd_soc_pcm512x_i2c 2566 0
snd_soc_bcm2708_i2s 8103 0
videodev 188498 3 uvcvideo,v4l2_common,videobuf2_core
snd_soc_tas5713 6079 0
snd_soc_pcm512x 20736 1 snd_soc_pcm512x_i2c
snd_soc_wm8804 9377 1 snd_soc_wm8804_i2c
regmap_mmio 4160 1 snd_soc_bcm2708_i2s
media 17918 2 uvcvideo,videodev
ati_remote 9399 0
rc_core 25765 7 rc_medion_x10_or2x,rc_it913x_v1,dvb_usb_v2,dvb_usb_af9035,ati_remote
snd_soc_core 197858 4 snd_soc_pcm512x,snd_soc_wm8804,snd_soc_tas5713,snd_soc_bcm2708_i2s
regmap_i2c 3450 4 snd_soc_pcm512x_i2c,snd_soc_wm8804_i2c,it913x,snd_soc_tas5713
snd_compress 9367 1 snd_soc_core
snd_pcm_dmaengine 5806 1 snd_soc_core
snd_pcm 115159 5 snd_soc_pcm512x,snd_soc_wm8804,snd_usb_audio,snd_soc_core,snd_pcm_dmaengine
snd_timer 24876 1 snd_pcm
snd 76139 9 snd_usb_audio,snd_soc_core,snd_hwdep,snd_timer,snd_pcm,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_compress
spi_bcm2708 6198 0
i2c_bcm2708 5970 0
w1_therm 4656 0
w1_gpio 4754 0
wire 34730 2 w1_gpio,w1_therm
cn 6041 1 wire
fuse 102189 1
ipv6 434017 46
root@osmc:~#
My motion conf
# Rename this distribution example file to motion.conf
This config file was generated by motion 3.2.12
Daemon
Start in daemon (background) mode and release terminal (default: off)
daemon on
File to store the process ID, also called pid file. (default: not defined)
process_id_file /var/run/motion/motion.pid
Basic Setup Mode
Start in Setup-Mode, daemon disabled. (default: off)
setup_mode off
Capture device options
Videodevice to be used for capturing (default /dev/video0)
for FreeBSD default is /dev/bktr0
v4l2_palette allows to choose preferable palette to be use by motion
to capture from those supported by your videodevice. (default: 8)
E.g. if your videodevice supports both V4L2_PIX_FMT_SBGGR8 and
V4L2_PIX_FMT_MJPEG then motion will by default use V4L2_PIX_FMT_MJPEG.
Setting v4l2_palette to 1 forces motion to use V4L2_PIX_FMT_SBGGR8
instead.
Values :
V4L2_PIX_FMT_SN9C10X : 0 ‘S910’
V4L2_PIX_FMT_SBGGR8 : 1 ‘BA81’
V4L2_PIX_FMT_MJPEG : 2 ‘MJPEG’
V4L2_PIX_FMT_JPEG : 3 ‘JPEG’
V4L2_PIX_FMT_RGB24 : 4 ‘RGB3’
V4L2_PIX_FMT_UYVY : 5 ‘UYVY’
V4L2_PIX_FMT_YUYV : 6 ‘YUYV’
V4L2_PIX_FMT_YUV422P : 7 ‘422P’
V4L2_PIX_FMT_YUV420 : 8 ‘YU12’
v4l2_palette 8
Tuner device to be used for capturing using tuner as source (default /dev/tuner0)
This is ONLY used for FreeBSD. Leave it commented out for Linux
; tunerdevice /dev/tuner0
The video input to be used (default: 8)
Should normally be set to 0 or 1 for video/TV cards, and 8 for USB cameras
input 8
The video norm to use (only for video capture and TV tuner cards)
Values: 0 (PAL), 1 (NTSC), 2 (SECAM), 3 (PAL NC no colour). Default: 0 (PAL)
norm 0
The frequency to set the tuner to (kHz) (only for TV tuner cards) (default: 0)
frequency 0
Rotate image this number of degrees. The rotation affects all saved images as
well as mpeg movies. Valid values: 0 (default = no rotation), 90, 180 and 270.
rotate 0
Image width (pixels). Valid range: Camera dependent, default: 352
width 320
Image height (pixels). Valid range: Camera dependent, default: 288
height 240
Maximum number of frames to be captured per second.
Valid range: 2-100. Default: 100 (almost no limit).
framerate 2
Minimum time in seconds between capturing picture frames from the camera.
Default: 0 = disabled - the capture rate is given by the camera framerate.
This option is used when you want to capture images at a rate lower than 2 per second.
minimum_frame_time 0
URL to use if you are using a network camera, size will be autodetected (incl http:// ftp:// or file:///)
Must be a URL that returns single jpeg pictures or a raw mjpeg stream. Default: Not defined
; netcam_url value
Username and password for network camera (only if required). Default: not defined
Syntax is user:password
; netcam_userpass value
The setting for keep-alive of network socket, should improve performance on compatible net cameras.
1.0: The historical implementation using HTTP/1.0, closing the socket after each http request.
keep_alive: Use HTTP/1.0 requests with keep alive header to reuse the same connection.
1.1: Use HTTP/1.1 requests that support keep alive as default.
Default: 1.0
; netcam_http 1.0
URL to use for a netcam proxy server, if required, e.g. “http://myproxy”.
If a port number other than 80 is needed, use “http://myproxy:1234”.
; netcam_proxy value
Set less strict jpeg checks for network cameras with a poor/buggy firmware.
Default: off
netcam_tolerant_check off
Let motion regulate the brightness of a video device (default: off).
The auto_brightness feature uses the brightness option as its target value.
If brightness is zero auto_brightness will adjust to average brightness value 128.
Only recommended for cameras without auto brightness
auto_brightness off
Set the initial brightness of a video device.
If auto_brightness is enabled, this value defines the average brightness level
which Motion will try and adjust to.
Valid range 0-255, default 0 = disabled
brightness 0
Set the contrast of a video device.
contrast 0
Set the saturation of a video device.
saturation 0
Set the hue of a video device (NTSC feature).
hue 0
Round Robin (multiple inputs on same video device name)
Number of frames to capture in each roundrobin step (default: 1)
roundrobin_frames 1
Number of frames to skip before each roundrobin step (default: 1)
roundrobin_skip 1
Try to filter out noise generated by roundrobin (default: off)
switchfilter off
Motion Detection Settings:
Threshold for number of changed pixels in an image that
triggers motion detection (default: 1500)
threshold 1500
Automatically tune the threshold down if possible (default: off)
threshold_tune off
Noise threshold for the motion detection (default: 32)
noise_level 32
Automatically tune the noise threshold (default: on)
noise_tune on
Despeckle motion image using (e)rode or (d)ilate or (l)abel (Default: not defined)
Recommended value is EedDl. Any combination (and number of) of E, e, d, and D is valid.
(l)abeling must only be used once and the ‘l’ must be the last letter.
Comment out to disable
despeckle EedDl
Detect motion in predefined areas (1 - 9). Areas are numbered like that: 1 2 3
A script (on_area_detected) is started immediately when motion is 4 5 6
detected in one of the given areas, but only once during an event. 7 8 9
One or more areas can be specified with this option. (Default: not defined)
; area_detect value
PGM file to use as a sensitivity mask.
Full path name to. (Default: not defined)
; mask_file value
Dynamically create a mask file during operation (default: 0)
Adjust speed of mask changes from 0 (off) to 10 (fast)
smart_mask_speed 0
Ignore sudden massive light intensity changes given as a percentage of the picture
area that changed intensity. Valid range: 0 - 100 , default: 0 = disabled
lightswitch 0
Picture frames must contain motion at least the specified number of frames
in a row before they are detected as true motion. At the default of 1, all
motion is detected. Valid range: 1 to thousands, recommended 1-5
minimum_motion_frames 1
Specifies the number of pre-captured (buffered) pictures from before motion
was detected that will be output at motion detection.
Recommended range: 0 to 5 (default: 0)
Do not use large values! Large values will cause Motion to skip video frames and
cause unsmooth mpegs. To smooth mpegs use larger values of post_capture instead.
pre_capture 0
Number of frames to capture after motion is no longer detected (default: 0)
post_capture 0
Gap is the seconds of no motion detection that triggers the end of an event
An event is defined as a series of motion images taken within a short timeframe.
Recommended value is 60 seconds (Default). The value 0 is allowed and disables
events causing all Motion to be written to one single mpeg file and no pre_capture.
gap 60
Maximum length in seconds of an mpeg movie
When value is exceeded a new mpeg file is created. (Default: 0 = infinite)
max_mpeg_time 0
Always save images even if there was no motion (default: off)
output_all off
Image File Output
Output ‘normal’ pictures when motion is detected (default: on)
Valid values: on, off, first, best, center
When set to ‘first’, only the first picture of an event is saved.
Picture with most motion of an event is saved when set to ‘best’.
Picture with motion nearest center of picture is saved when set to ‘center’.
Can be used as preview shot for the corresponding movie.
output_normal on
Output pictures with only the pixels moving object (ghost images) (default: off)
output_motion off
The quality (in percent) to be used by the jpeg compression (default: 75)
quality 75
Output ppm images instead of jpeg (default: off)
ppm off
FFMPEG related options
Film (mpeg) file output, and deinterlacing of the video input
The options movie_filename and timelapse_filename are also used
by the ffmpeg feature
Use ffmpeg to encode mpeg movies in realtime (default: off)
ffmpeg_cap_new on
Use ffmpeg to make movies with only the pixels moving
ffmpeg_cap_motion off
Use ffmpeg to encode a timelapse movie
Default value 0 = off - else save frame every Nth second
ffmpeg_timelapse 0
The file rollover mode of the timelapse video
Valid values: hourly, daily (default), weekly-sunday, weekly-monday, monthly, manual
ffmpeg_timelapse_mode daily
Bitrate to be used by the ffmpeg encoder (default: 400000)
This option is ignored if ffmpeg_variable_bitrate is not 0 (disabled)
ffmpeg_bps 500000
Enables and defines variable bitrate for the ffmpeg encoder.
ffmpeg_bps is ignored if variable bitrate is enabled.
Valid values: 0 (default) = fixed bitrate defined by ffmpeg_bps,
or the range 2 - 31 where 2 means best quality and 31 is worst.
ffmpeg_variable_bitrate 0
Codec to used by ffmpeg for the video compression.
Timelapse mpegs are always made in mpeg1 format independent from this option.
Supported formats are: mpeg1 (ffmpeg-0.4.8 only), mpeg4 (default), and msmpeg4.
mpeg1 - gives you files with extension .mpg
mpeg4 or msmpeg4 - gives you files with extension .avi
msmpeg4 is recommended for use with Windows Media Player because
it requires no installation of codec on the Windows client.
swf - gives you a flash film with extension .swf
flv - gives you a flash video with extension .flv
ffv1 - FF video codec 1 for Lossless Encoding ( experimental )
mov - QuickTime ( testing )
ffmpeg_video_codec swf
Use ffmpeg to deinterlace video. Necessary if you use an analog camera
and see horizontal combing on moving objects in video or pictures.
(default: off)
ffmpeg_deinterlace off
Snapshots (Traditional Periodic Webcam File Output)
Make automated snapshot every N seconds (default: 0 = disabled)
snapshot_interval 0
Text Display
%Y = year, %m = month, %d = date,
%H = hour, %M = minute, %S = second, %T = HH:MM:SS,
%v = event, %q = frame number, %t = thread (camera) number,
%D = changed pixels, %N = noise level, \n = new line,
%i and %J = width and height of motion area,
%K and %L = X and Y coordinates of motion center
%C = value defined by text_event - do not use with text_event!
You can put quotation marks around the text to allow
leading spaces
Locate and draw a box around the moving object.
Valid values: on, off and preview (default: off)
Set to ‘preview’ will only draw a box in preview_shot pictures.
locate off
Draws the timestamp using same options as C function strftime(3)
Default: %Y-%m-%d\n%T = date in ISO format and time in 24 hour clock
Text is placed in lower right corner
text_right %Y-%m-%d\n%T-%q
Draw a user defined text on the images using same options as C function strftime(3)
Default: Not defined = no text
Text is placed in lower left corner
; text_left CAMERA %t
Draw the number of changed pixed on the images (default: off)
Will normally be set to off except when you setup and adjust the motion settings
Text is placed in upper right corner
text_changes off
This option defines the value of the special event conversion specifier %C
You can use any conversion specifier in this option except %C. Date and time
values are from the timestamp of the first image in the current event.
Default: %Y%m%d%H%M%S
The idea is that %C can be used filenames and text_left/right for creating
a unique identifier for each event.
text_event %Y%m%d%H%M%S
Draw characters at twice normal size on images. (default: off)
text_double off
Target Directories and filenames For Images And Films
For the options snapshot_, jpeg_, mpeg_ and timelapse_filename
you can use conversion specifiers
Quotation marks round string are allowed.
Target base directory for pictures and films
Recommended to use absolute path. (Default: current working directory)
target_dir /media/webcam/motion
File path for snapshots (jpeg or ppm) relative to target_dir
Default: %v-%Y%m%d%H%M%S-snapshot
Default value is equivalent to legacy oldlayout option
For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-snapshot
File extension .jpg or .ppm is automatically added so do not include this.
Note: A symbolic link called lastsnap.jpg created in the target_dir will always
point to the latest snapshot, unless snapshot_filename is exactly ‘lastsnap’
snapshot_filename %v-%Y%m%d%H%M%S-snapshot
File path for motion triggered images (jpeg or ppm) relative to target_dir
Default: %v-%Y%m%d%H%M%S-%q
For Motion 3.0 compatible mode choose: %Y/%m/%d/%H/%M/%S-%q
Set to ‘preview’ together with best-preview feature enables special naming
convention for preview shots. See motion guide for details
jpeg_filename %v-%Y%m%d%H%M%S-%q
File path for motion triggered ffmpeg films (mpeg) relative to target_dir
For Motion 3.0 compatible mode choose: %Y/%m/%d/%H%M%S
File extension .mpg or .avi is automatically added so do not include this
This option was previously called ffmpeg_filename
movie_filename %v-%Y%m%d%H%M%S
File path for timelapse mpegs relative to target_dir
Default: %Y%m%d-timelapse
Default value is near equivalent to legacy oldlayout option
For Motion 3.0 compatible mode choose: %Y/%m/%d-timelapse
File extension .mpg is automatically added so do not include this
timelapse_filename %Y%m%d-timelapse
Live Webcam Server
The mini-http server listens to this port for requests (default: 0 = disabled)
webcam_port 8088
Quality of the jpeg (in percent) images produced (default: 50)
webcam_quality 50
Output frames at 1 fps when no motion is detected and increase to the
rate given by webcam_maxrate when motion is detected (default: off)
webcam_motion off
Maximum framerate for webcam streams (default: 1)
webcam_maxrate 1
Restrict webcam connections to localhost only (default: on)
webcam_localhost off
Limits the number of images per connection (default: 0 = unlimited)
Number can be defined by multiplying actual webcam rate by desired number of seconds
Actual webcam rate is the smallest of the numbers framerate and webcam_maxrate
webcam_limit 0
HTTP Based Control
TCP/IP port for the http server to listen on (default: 0 = disabled)
control_port 8089
Restrict control connections to localhost only (default: on)
control_localhost off
Output for http server, select off to choose raw text plain (default: on)
control_html_output on
Authentication for the http based control. Syntax username:password
Default: not defined (Disabled)
; control_authentication username:password
Tracking (Pan/Tilt)
Type of tracker (0=none (default), 1=stepper, 2=iomojo, 3=pwc, 4=generic, 5=uvcvideo)
The generic type enables the definition of motion center and motion size to
be used with the conversion specifiers for options like on_motion_detected
track_type 0
Enable auto tracking (default: off)
track_auto off
Serial port of motor (default: none)
; track_port value
Motor number for x-axis (default: 0)
track_motorx 0
Motor number for y-axis (default: 0)
track_motory 0
Maximum value on x-axis (default: 0)
track_maxx 0
Maximum value on y-axis (default: 0)
track_maxy 0
ID of an iomojo camera if used (default: 0)
track_iomojo_id 0
Angle in degrees the camera moves per step on the X-axis
with auto-track (default: 10)
Currently only used with pwc type cameras
track_step_angle_x 10
Angle in degrees the camera moves per step on the Y-axis
track_step_angle_y 10
Delay to wait for after tracking movement as number
of picture frames (default: 10)
track_move_wait 10
Speed to set the motor to (stepper motor option) (default: 255)
track_speed 255
Number of steps to make (stepper motor option) (default: 40)
track_stepsize 40
External Commands, Warnings and Logging:
You can use conversion specifiers for the on_xxxx commands
%f = filename with full path
%n = number indicating filetype
Both %f and %n are only defined for on_picture_save,
on_movie_start and on_movie_end
Do not sound beeps when detecting motion (default: on)
Note: Motion never beeps when running in daemon mode.
quiet on
Command to be executed when an event starts. (default: none)
An event starts at first motion detected after a period of no motion defined by gap
; on_event_start value
Command to be executed when an event ends after a period of no motion
(default: none). The period of no motion is defined by option gap.
; on_event_end value
Command to be executed when a picture (.ppm|.jpg) is saved (default: none)
To give the filename as an argument to a command append it with %f
; on_picture_save value
Command to be executed when a motion frame is detected (default: none)
; on_motion_detected value
Command to be executed when motion in a predefined area is detected
Check option ‘area_detect’. (default: none)
; on_area_detected value
Command to be executed when a movie file (.mpg|.avi) is created. (default: none)
; on_movie_start value
Command to be executed when a movie file (.mpg|.avi) is closed. (default: none)
; on_movie_end value
Command to be executed when a camera can’t be opened or if it is lost
NOTE: There is situations when motion doesn’t detect a lost camera!
It depends on the driver, some drivers don’t detect a lost camera at all
Some hang the motion thread. Some even hang the PC! (default: none)
; on_camera_lost value
Common Options For MySQL and PostgreSQL database features.
Options require the MySQL/PostgreSQL options to be active also.
Log to the database when creating motion triggered image file (default: on)
sql_log_image on
Log to the database when creating a snapshot image file (default: on)
sql_log_snapshot on
Log to the database when creating motion triggered mpeg file (default: off)
sql_log_mpeg off
Log to the database when creating timelapse mpeg file (default: off)
sql_log_timelapse off
SQL query string that is sent to the database
Use same conversion specifiers has for text features
Additional special conversion specifiers are
%n = the number representing the file_type
Default value:
insert into security(camera, filename, frame, file_type, time_stamp, text_event) values(’%t’, ‘%f’, ‘%q’, ‘%n’, ‘%Y-%m-%d %T’, ‘%C’)
sql_query insert into security(camera, filename, frame, file_type, time_stamp, event_time_stamp) values(’%t’, ‘%f’, ‘%q’, ‘%n’, ‘%Y-%m-%d %T’, ‘%C’)
Database Options For MySQL
Mysql database to log to (default: not defined)
; mysql_db value
The host on which the database is located (default: localhost)
; mysql_host value
User account name for MySQL database (default: not defined)
; mysql_user value
User password for MySQL database (default: not defined)
; mysql_password value
Database Options For PostgreSQL
PostgreSQL database to log to (default: not defined)
; pgsql_db value
; pgsql_host value
User account name for PostgreSQL database (default: not defined)
; pgsql_user value
User password for PostgreSQL database (default: not defined)
; pgsql_password value
Port on which the PostgreSQL database is located (default: 5432)
; pgsql_port 5432
Video Loopback Device (vloopback project)
Output images to a video4linux loopback device
The value ‘-’ means next available (default: not defined)
; video_pipe value
Output motion images to a video4linux loopback device
; motion_video_pipe value
Thread config files - One for each camera.
Except if only one camera - You only need this config file.
If you have more than one camera you MUST define one thread
config file for each camera in addition to this config file.
Remember: If you have more than one camera you must have one
thread file for each camera. E.g. 2 cameras requires 3 files:
This motion.conf file AND thread1.conf and thread2.conf.
Only put the options that are unique to each camera in the
thread config files.
; thread /usr/local/etc/thread1.conf
; thread /usr/local/etc/thread2.conf
; thread /usr/local/etc/thread3.conf
; thread /usr/local/etc/thread4.conf
