Hello! Does anyone know if OpenHAB (installed on OSMC) use much of the raspberry pi 2 B resources.
I want to install OpenHAB but im worried that it will make my PI slow.
i would say that it can work side by side with Kodi.
it only needs java dont think it would effect it so much, you can try atleast and if it slows it down then remove it
just make sure to pick another port in the config so it doesnt conflict with kodi
out of curiosity how did it perform ?
Sorry for the late reply. At the moment it works fine (still has 400mb free ram when both is running). But “uptime-wise” i will be moving the openHAB installation to a second PI.
