OSMC and Playstation 4 Issues
Hello,
I recently just started setting up a Raspberry Pi 2 to be used as a home OTA DVR using the Hauppauge 1191 WinTV-HVR-950Q. Everything worked great with the TvHeadend from the App Store except for the Channel guide. No big deal was able to get that working pretty easily. Now the only issue that I have is getting playback to work on my network with my Playstation 4. On the PS4, I am using the Media center app which has the Pi showing up and I can access everything perfectly. However, after about a few minutes of the pi being active, the pi will just disappear and never show back up unless the system is rebooted. I believe that this is an issue with the samba server however, I am not exactly sure where to look. I have checked the journalctl logs and the samba logs but have not found any issues. Any suggestions as to what the issue could be or where I could start trying to track down the possible issue?
Thank you,
Chaz
A lot of IPTV Plugins have power save functions…This could be an issue?!
