I’m trying to setup a new OSMC install with a WD My Cloud. I can mount the NFS storage with sudo mount -t nfs 192.168.1.100:/nfs /mnt/test but i can’t access password-protected folders. I’d like it for the folders to stay mounted permanently and i’d also like to use transmission with it… Any hints on how to configure fstab or something else? Thanks in advance.
Well the fstab entry i provided specifically states “nouser” so if you needed to access a folder which was username and password protected, you would need to figure out how to provide these credentials through fstab.
