My external HDD was always mounted in /media/Elements, but once I pulled mistakenly usb cable and inserted it again, and HDD automatically mounted into /media/Elements_. I re-mounted it manually to /media/Elements (as no movies was found due ti reason that library is looking at /medial/Elements). But now after each reboot it’s automatically mounted to /media/Elements_ and I can’t find any settings that I can change this behaviour.
Can you also please show the output of the following 2 commands:
sudo blkid sudo mount
Well I’ve tried to upload logs and got this :
root@osmc:/home/osmc# grab-logs -A
Logs successfully uploaded.
Logs available at https://paste.osmc.tv/
No proper url was returned.
So I copied kodi.log manually : https://paste.osmc.tv/iporubafey.coffee
I enabled logs in kodi settings, and rebooted the system, HDD was automounted to /media/Elemeents_
sudo mount :
devtmpfs on /dev type devtmpfs (rw,relatime,size=377792k,nr_inodes=94448,mode=755)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
tmpfs on /run type tmpfs (rw,relatime)
/dev/mmcblk0p2 on / type ext4 (rw,relatime,stripe=1024,data=ordered)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=21,pgrp=1,timeout=300,minproto=5,maxproto=5,direct)
mqueue on /dev/mqueue type mqueue (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
systemd-1 on /boot type autofs (rw,relatime,fd=33,pgrp=1,timeout=300,minproto=5,maxproto=5,direct)
configfs on /sys/kernel/config type configfs (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
/dev/sda1 on /media/Elements_ type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks)
/dev/mmcblk0p1 on /boot type vfat (rw,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=76584k,mode=700,uid=1000,gid=1000)
