I have a few video files with closed captions. I can see these captions in VLC windows player but OSMC does not show these captions. I have enabled closed captions in Settings, Player, Language screen.
Linux osmc 4.14.78-4-osmc on raspberry pi 3b+
MediaInfo shows this info about the video file-
General
Complete name : C:\temp\great-human-odyssey.mp4
Format : MPEG-TS
File size : 1.53 GiB
Duration : 58 min 59 s
Overall bit rate : 3 708 kb/s
Law rating : TV-PG
FileExtension_Invalid : ts m2t m2s m4t m4s tmf ts tp trp ty
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 2 frames
Codec ID : 27
Duration : 58 min 58 s
Bit rate mode : Variable
Bit rate : 3 137 kb/s
Maximum bit rate : 12.0 Mb/s
Width : 1 280 pixels
Height : 540 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 (30000/1001) FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.151
Stream size : 1.29 GiB (85%)
Color range : Limited
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : 129
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -1 s 112 ms
Stream size : 162 MiB (10%)
Language : English
Service kind : Complete Main
Text #1
ID : 49 (0x31)-CC1
Menu ID : 1 (0x1)
Format : EIA-608
Muxing mode : SCTE 128 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
CaptionServiceName : CC1
Text #2
Menu ID : 1 (0x1)
Format : EIA-708
