Hi. Just started the update and after all where done I only get -smile… What to do?
Can you SSH into the device? Provide logs.
https://osmc.tv/wiki/general/how-to-submit-a-useful-support-request/
Update broke my osmc as well. Think the error said unable to install or update libd-bin or something similar to that.
[code]17:41:05.076 T:1958871040 NOTICE: special://profile/ is mapped to: special://masterprofile/
17:41:05.076 T:1958871040 NOTICE: -----------------------------------------------------------------------
17:41:05.076 T:1958871040 NOTICE: Starting Kodi (17.4). Platform: Linux ARM (Thumb) 32-bit
17:41:05.076 T:1958871040 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
17:41:05.076 T:1958871040 NOTICE: Kodi compiled Aug 27 2017 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.39 (200743)
17:41:05.076 T:1958871040 NOTICE: Running on Open Source Media Center 2017.08-1, kernel: Linux ARM 32-bit version 4.9.29-9-osmc
17:41:05.076 T:1958871040 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
17:41:05.076 T:1958871040 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
17:41:05.077 T:1958871040 NOTICE: ARM Features: Neon disabled
17:41:05.077 T:1958871040 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
17:41:05.077 T:1958871040 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
17:41:05.077 T:1958871040 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
17:41:05.077 T:1958871040 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
17:41:05.077 T:1958871040 NOTICE: special://envhome/ is mapped to: /home/osmc
17:41:05.077 T:1958871040 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
17:41:05.077 T:1958871040 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
17:41:05.077 T:1958871040 NOTICE: special://logpath/ is mapped to: /home/osmc/.kodi/temp
17:41:05.077 T:1958871040 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
17:41:05.077 T:1958871040 NOTICE: Local hostname: osmc.rpi3
17:41:05.077 T:1958871040 NOTICE: Log File is located: /home/osmc/.kodi/temp//kodi.log
17:41:05.077 T:1958871040 NOTICE: -----------------------------------------------------------------------
17:41:05.084 T:1958871040 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
17:41:05.097 T:1958871040 NOTICE: load settings…
17:41:05.229 T:1958871040 NOTICE: Found 2 Lists of Devices
17:41:05.229 T:1958871040 NOTICE: Enumerated PI devices:
17:41:05.229 T:1958871040 NOTICE: Device 1
17:41:05.230 T:1958871040 NOTICE: m_deviceName : HDMI
17:41:05.230 T:1958871040 NOTICE: m_displayName : HDMI
17:41:05.230 T:1958871040 NOTICE: m_displayNameExtra:
17:41:05.230 T:1958871040 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
17:41:05.230 T:1958871040 NOTICE: m_channels : FL,FR
17:41:05.230 T:1958871040 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
17:41:05.230 T:1958871040 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
17:41:05.230 T:1958871040 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
17:41:05.230 T:1958871040 NOTICE: Device 2
17:41:05.230 T:1958871040 NOTICE: m_deviceName : Analogue
17:41:05.230 T:1958871040 NOTICE: m_displayName : Analogue
17:41:05.230 T:1958871040 NOTICE: m_deviceType : AE_DEVTYPE_PCM
17:41:05.230 T:1958871040 NOTICE: m_sampleRates : 48000
17:41:05.230 T:1958871040 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
17:41:05.230 T:1958871040 NOTICE: m_streamTypes : No passthrough capabilities
17:41:05.230 T:1958871040 NOTICE: Device 3
17:41:05.230 T:1958871040 NOTICE: m_deviceName : Both
17:41:05.230 T:1958871040 NOTICE: m_displayName : HDMI and Analogue
17:41:05.230 T:1958871040 NOTICE: Enumerated ALSA devices:
17:41:05.231 T:1958871040 NOTICE: Device 1
17:41:05.231 T:1958871040 NOTICE: m_deviceName : @
17:41:05.231 T:1958871040 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
17:41:05.231 T:1958871040 NOTICE: m_displayNameExtra:
17:41:05.231 T:1958871040 NOTICE: m_deviceType : AE_DEVTYPE_PCM
17:41:05.231 T:1958871040 NOTICE: m_channels : FL,FR
17:41:05.231 T:1958871040 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000
17:41:05.231 T:1958871040 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
17:41:05.231 T:1958871040 NOTICE: m_streamTypes : No passthrough capabilities
17:41:05.246 T:1958871040 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
17:41:05.246 T:1958871040 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are…
<?xml version="1.0" encoding="UTF-8" ?>
540
720
false
0
30
17:41:05.248 T:1958871040 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
17:41:05.249 T:1958871040 NOTICE: Contents of special://profile/advancedsettings.xml are…
1
52428800
2.0
17:41:05.250 T:1958871040 NOTICE: Default Video Player: VideoPlayer
17:41:05.250 T:1958871040 NOTICE: Default Audio Player: paplayer
17:41:05.250 T:1958871040 NOTICE: Disabled debug logging due to GUI setting. Level 0.
17:41:05.250 T:1958871040 NOTICE: Log level changed to “LOG_LEVEL_NORMAL”
17:41:05.250 T:1958871040 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
17:41:05.251 T:1958871040 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:41:05.252 T:1958871040 NOTICE: Loaded playercorefactory configuration
17:41:05.252 T:1958871040 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:41:05.252 T:1958871040 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:41:05.366 T:1958871040 NOTICE: Running database version Addons27
17:41:06.175 T:1958871040 NOTICE: ADDONS: Using repository repository.xbmc.org
17:41:06.351 T:1958871040 NOTICE: Raspberry PI firmware version: Jul 22 2017 00:01:46
Copyright © 2012 Broadcom
version f52771674311a841405cea05e8738a526dd60ee1 (clean) (release)
17:41:06.351 T:1958871040 NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
17:41:06.351 T:1958871040 NOTICE: cache.memorysize: 20MB libass.cache: 0MB
17:41:06.351 T:1958871040 NOTICE: Config:
arm_freq=1000
audio_pwm_mode=1
config_hdmi_boost=5
core_freq=500
desired_osc_freq=0x36ee80
disable_commandline_tags=2
disable_l2cache=1
disable_splash=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_ignore_cec_init=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage=2
over_voltage_avs=0x10c8e
over_voltage_avs_boost=0x10c8e
over_voltage_sdram_p=2
pause_burst_frames=1
program_serial_random=1
sdram_freq=500
temp_limit=85
device_tree=-
17:41:06.361 T:1958871040 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
17:41:06.363 T:1958871040 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 60.000000 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 59.940063 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 60.000000 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 59.940063 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
17:41:06.363 T:1958871040 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
17:41:06.364 T:1958871040 NOTICE: Found (1920x1080@60.000000) at 28, setting to RES_DESKTOP at 16
17:41:06.364 T:1958871040 NOTICE: Checking resolution 16
17:41:06.668 T:1958871040 NOTICE: GL_VENDOR = Broadcom
17:41:06.668 T:1958871040 NOTICE: GL_RENDERER = VideoCore IV HW
17:41:06.668 T:1958871040 NOTICE: GL_VERSION = OpenGL ES 2.0
17:41:06.668 T:1958871040 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
17:41:06.668 T:1958871040 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
17:41:08.930 T:1938813936 NOTICE: Running database version Addons27
17:41:08.931 T:1938813936 NOTICE: Running database version ViewModes6
17:41:08.932 T:1938813936 ERROR: SQL: [Textures13.db] The database disk image is malformed
Query: PRAGMA cache_size=4096
17:41:08.932 T:1938813936 ERROR: Connect failed with 'SQL: [Textures13.db] The database disk image is malformed
17:41:08.934 T:1938813936 ERROR: SQL: [Textures13.db] The database disk image is malformed
Query: PRAGMA default_cache_size=4096
17:41:08.935 T:1938813936 ERROR: Connect failed with 'SQL: [Textures13.db] The database disk image is malformed
17:41:08.935 T:1938813936 ERROR: Unable to create new database
17:41:08.939 T:1938813936 NOTICE: Running database version MyMusic60
17:41:08.939 T:1830810608 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
17:41:08.948 T:1938813936 NOTICE: Running database version MyVideos107
17:41:08.950 T:1938813936 NOTICE: Running database version TV29
17:41:08.951 T:1938813936 NOTICE: Running database version Epg11
17:41:08.953 T:1958871040 NOTICE: start dvd mediatype detection
17:41:10.506 T:1958871040 WARNING: JSONRPC: Could not parse type “Setting.Details.SettingList”
[/code]
Your actual issue appears to be some database corruption
But full logs are needed to see update status.
Probably not a good idea to do '+1’s on a thread that will likely have different problems.
Sorry about that. I disconnected it because it only did sadface loop, and reconnected it now to get logs. It started, but some skin settings were lost. Said error installing libc-bin again at startup. But it started and is alive, so never mind me.
You will have an issue when you update later then. It’s worth finding out what the issue is.
