Osmc fail on reboot
I just did ‘reboot’ from Kodi (Pi3), and now I see only:
error while loading shared libraries: /lib/arm-linix-gnueabihf/libpcre.so.3: Unable to run arch-specific checks
init: error while loading shared libraries: /lib/arm-linix-gnueabihf/libpcre.so.3: Unable to run arch-specific checks
Nothing beyond this.
Is my only way out to do a fresh install of OSMC/Kodi?
Can you get ssh access? Logs would be useful.
No. The OS does not seem to come up. No way to get an ssh that I know of. Sorry about no logs. In a couple of days I’ll be home and I’ll try to load up the card in Windows and see if I can find some log files.
Windows will not provide access to any useful logs. It might be worth a reinstall.
You could try to access kodi log with this utillity program: Access to Ext 2/3/4, HFS and ReiserFS from Windows | DiskInternals
That utility will give access to the Kodi log but not to the system journal or dmesg since (a) systemd now writes these in a binary format and (b) AFAIK they’re only in tmpfs by default on OSMC.
