Hi all,
i just reinstalled OSMC on my RP1
At the first dist-upgrade i have this error
Preparing to unpack …/libc6_2.28-110.1_armhf.deb …
Unpacking libc6:armhf (2.28-110.1) over (2.28-10+rpi1) …
dpkg: warning: old libc6:armhf package post-removal script subprocess was killed by signal (Segmentation fault)
dpkg: trying script from the new package instead …
dpkg: error processing archive /var/cache/apt/archives/libc6_2.28-110.1_armhf.deb (–unpack):
new libc6:armhf package post-removal script subprocess was killed by signal (Segmentation fault)
dpkg: error while cleaning up:
installed libc6:armhf package pre-installation script subprocess was killed by signal (Segmentation fault)
I’ll try all to fix this but with no success
Can anyone help me?
Someone with this same issue?
May the lib is broken?
The SD card is ok and brand new and this is the problem that made me reinstall the whole system but i have the same issue
