OSMC hdd 3.5" compatibility
hi
Im thinking of buying this good quality enclosure https://www.amazon.in/gp/aw/d/B011RFMOAK/ref=cm_cr_arp_mb_bdcrb_top?ie=UTF8
for a 500gb 3.5" sata 3 hard disk that i have. will osmc support it since it says enclosure is plug and play but enclosure does not mention raspberry pi on its page.Should i just buy freely or should i be worried ?
I wouldn’t expect it to mention Raspberry Pi for compatibility. Looks like a standard USB enclosure su yes, I’d expect it to work just fine
i thinks an usb box whit a your and external power supply it’s the best solution…
