Greetings,
I have an RPI 3 and i wanted to install OSMC on this device.
However for performance i wanted to put the boot info on the SD card and the OS to run via NFS. But i’m having a very troublesome problem.
I’ve tried all combinations that i can think of (in terms of mount options in exports).
OSMC will boot initially and install the OS files (i can see them on the share) yet after reboot i get these errors and nothing much happens:
The server that is running the NFS share is Debian Jessie:
Linux version 3.16.0-4-amd64 (debian-kernel@lists.debian.org) (gcc version 4.8.4 (Debian 4.8.4-1) ) #1 SMP Debian 3.16.7-ckt25-1 (2016-03-06)
This is my NFS share config:
/media/storage/osmc_boot 192.168.1.3(rw,fsid=0,async,no_root_squash,no_all_squash,no_subtree_check,insecure)
The NFS share is a created on a mountpoint on my software raid (mdadm) running XFS filesystem.
The IP listed above IS the RPI (configured via DHCP reservation)
This is are the folder permissions on the nfs presented share.
drwxrwxrwx 22 root root 4.0K Jul 27 13:01 osmc_boot
As said, OSMC does install on first boot and appears to put its files correctly in the folders.
root@arkp-nas:/media/storage/osmc_boot# ls -lh
total 36K
drwxr-xr-x 2 root root 4.0K Jul 27 12:57 bin
drwxr-xr-x 2 root root 10 Jul 27 13:02 boot
drwxr-xr-x 4 root root 4.0K Jul 27 12:57 dev
drwxr-xr-x 67 root root 4.0K Jul 27 13:03 etc
drwxr-xr-x 3 root root 25 Jul 27 12:57 home
drwxr-xr-x 15 root root 4.0K Jul 27 12:58 lib
drwxr-xr-x 2 root root 10 Mar 2 00:45 lib64
drwxr-xr-x 2 root root 27 Jul 27 12:58 media
drwxr-xr-x 2 root root 10 Jun 21 16:16 mnt
drwxr-xr-x 3 root root 23 Jul 27 12:58 opt
drwxr-xr-x 2 root root 10 May 30 05:40 proc
drwx------ 2 root root 47 Jul 27 12:58 root
drwxr-xr-x 5 root root 71 Jul 27 12:58 run
drwxr-xr-x 2 root root 4.0K Jul 27 12:58 sbin
drwxr-xr-x 2 root root 10 Mar 2 00:45 selinux
drwxr-xr-x 2 root root 10 Jun 21 16:16 srv
drwxr-xr-x 2 root root 10 Apr 6 2015 sys
drwxrwxrwt 7 root root 132 Jul 27 13:12 tmp
drwxr-xr-x 12 root root 4.0K Jul 27 13:01 usr
drwxr-xr-x 11 root root 4.0K Jul 27 13:02 var
When i am eventually able to login to the RPI and check the services like it says, i get the following error:
osmc@osmc:~$ systemctl status systemd-journal-flush.service
Failed to get properties: Connection timed out
Does anyone have any suggestions what to check? It sounds like a permissions problem, but i’ve tried with 777 all the way down just in case and i’ve re-imaged the card multiple times after each config change to either NFS or something else. Each time i’ve also removed the osmc boot folder and re-created.
I must be missing something, however the googling of errors doesn’t appear to help me with the scenario i’m in.
Any comments or suggestions welcome. Happy to provide anymore info if required
