I’ve been using osmc on a pi 0 w for several hours now. crashes frequently when navigating. is this common behavior? power supply is 2 amps and drives an rpi 3 with no issues.
reminds me of some of the issues i used to have with the rpi 1 b.
I’m not interested in a resolution really. Just curious if it’s normal to be crashy on the pi 0. I remember it used to be on the rpi 1 b that if you navigated menus with a large number of items, it would often crash. this was back in the raspbmc and early osmc days. that got better with time and updates but wasn’t totally resolved when i switched to rpi 2.
i put openelec on it and so far no crashes. i don’t plan to run kodi on this regardless. have some pi 2s doing that duty. only installed osmc and kodi to see if the pi 0 was up to the task. at this point, while i prefer osmc i think i’ll recommend openelec for the pi 0.
however, if it’s not known to be crashy on the pi 0, i can reinstall it and create some logs if you think that would help the project. but i’m not going to run kodi on it.
