OSMC is not starting somehow (Raspery Pi B+)
I just installed the latest OSMC image (2016.02-3) with the OSMC installer on a Linux Debian system. Internet connection is wired. In my network there is a DHCP server running.
The Raspi is connected vai HDMI to the TV. When I turn Power on the TV reacts correctly showing that the HDMI input channel is activated by the Raspi, and the coloured start screen appears…
…and then: nothing happens - I waited 10 minutes.
How can I debug this situation? What can I do?
Regards
StePad
Did you use the correct image?
Do you see any lights on the PI flashing?
I used “Rasperry Pi 2/3”.
I saw the Power on lights flashing red, but the internet connection lights did not flash.
I tried an older version, 2015 something, with no change in behavior.
I suspect the power supply to be to weak (5V, 1A).
Regards
StePad
Definitely too weak.
