Not sure if this is an OSMC issue or a Kodi issue.
But when adding new TV Episodes, they are not shown after doing a Library Update.
I have to manually go to each show and refresh all its data for episodes to appear.
Any idea why this could be?
Can we just enable WatchDog?
Are you sure that file and folder names are correct.
Naming video files/TV shows
What are you talking about,…if you have nothing useful to report please do not respond and go play somewhere else.
Yes, naming is correct because when i force the tv show refresh it finds the new episodes added.
I’ll try, thanks.
Like i said before, the problem is not with Naming conventions, because the file is found if I manually refresh the entire show library.
