OSMC not mounting my USB drive
Hi, i have moved from Raspbmc to OSMC Alpha 4 and now my 2TB External Drive isn’t mounting.
Its a 2TB exFAT formatted, i see it when i type fdisk -l
osmc@osmc:~$ fdisk -l
Disk /dev/sda: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x25931207
Device     Boot Start        End    Sectors  Size Id Type
/dev/sda1           2 3907029167 3907029166  1.8T  7 HPFS/NTFS/exFAT
but it’s not mounted when i turn the RaspberryPi on.
it worked fine on Raspbmc.
what should i do to make it work?
Thanks.
I found the solution, all i had to do is:
sudo apt-get install exfat-fuse exfat-utils
and then reboot and everything is working great!
