I was watching TV when OSMC went weird, as if I was reacting to non-existent keypresses.
I reset the Pi and it would not boot, giving 4 flashes on the green LED.
I checked the SD card; it seems ok but there is no start.elf or loader.bin (suggested as a possible cause by the internet).
I put the newest OSMC on a new card and it booted fine. The old card had a pre-Kodi 19 release on it.
So:
- can I fix my old card
- or should I use the opportunity to upgrade
- is my old SD card now suspect
- is my Pi possibly getting old and misbehaving?
Any other advice?
David
