actually I’m enjoying OSMC quite well since the first stable release. But today I ran into an problem:
The pi is always-on and after I turned on the TV today, it presented me nothing but a black screen. After a hard-reboot (unplug USB energy) the device seems to hang up at boot with the following lines:
Does anyone know what to do?
The only hardware, that is connected is a 720p-TV via HDMI, IR-receiver, and an USB stick (for USB-boot, which worked well the last weeks since installing OSMC).
After trying to fsck the USB with a Linux Mint VM (which didn’t work because VMware can’t pass non-mounted devices through to VM) I installed a Linux Mint partition on my Mac… Everything to end up in still not being able to mount the USB. I’ll attach regarding outputs:
dmesg “sees” the USB stick after plugging in:
[ 55.106258] usb 3-1: new high-speed USB device number 2 using xhci_hcd
[ 55.239960] usb 3-1: New USB device found, idVendor=0951, idProduct=1642
[ 55.239963] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 55.239965] usb 3-1: Product: DT 101 G2
[ 55.239966] usb 3-1: Manufacturer: Kingston
[ 55.239968] usb 3-1: SerialNumber: 001CC0EC348DBC31E64501F9
[ 55.247420] usb-storage 3-1:1.0: USB Mass Storage device detected
[ 55.247530] scsi6 : usb-storage 3-1:1.0
[ 55.247622] usbcore: registered new interface driver usb-storage
[ 55.249142] usbcore: registered new interface driver uas
[ 56.284168] scsi 6:0:0:0: Direct-Access Kingston DT 101 G2 PMAP PQ: 0 ANSI: 0 CCS
[ 56.284586] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 57.333955] sd 6:0:0:0: [sdb] 4096 512-byte logical blocks: (2.09 MB/2.00 MiB)
[ 57.335912] sd 6:0:0:0: [sdb] Write Protect is off
[ 57.335930] sd 6:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 57.337805] sd 6:0:0:0: [sdb] No Caching mode page found
[ 57.337808] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 57.367227] sdb: sdb1
[ 57.367247] sdb: p1 start 4096 is beyond EOD, enabling native capacity
[ 57.372904] sdb: sdb1
[ 57.372907] sdb: p1 start 4096 is beyond EOD, truncated
[ 57.377700] sd 6:0:0:0: [sdb] Attached SCSI removable disk
This results in the typical “blob” sound for plugging devices in the USB port, but it’s not going to be mounted:
mount -l
fsck while a partition being mounted is not a good idea - that’s right at all. But AFAIK I have to mount the partition first, so I can use the old mount point (after unmounting) as parameter for fsck.
So my question is: How do I reference to the partition if it was never mounted?
fsck von util-linux 2.20.1
e2fsck 1.42.9 (4-Feb-2014)
fsck.ext2: Datei oder Verzeichnis nicht gefunden beim Versuch, /dev/sdb1 zu öffnen
Ist das Gerät möglicherweise nicht vorhanden?
Sorry - German console. It’s the default “file or directory not found (…) Is the device maybe not present?” error message.
That’s why I thought the device has first to be mounted and unmounted.
No, you do not need to mount a device before running fsck, it is enough that the block device (/dev/sdb1) exists. After booting up with the drive connected please provide the output of dmesg:
Okay - thanks for the explanation.
The “paste-log” command is not found on my machine. So I was just able to create an output after booting w/ connected device via “dmesg”. Because it’s a really long output, I uploaded it as txt on dropbox (didn’t want my post to explode, as I can see no spoiler-option in the forum-SW). Dropbox - Error
Sam, many thanks go also to you for your effort!
parted was already installed on my machine - but your command results in an empty output (so just a new line waiting for the next command). I also tried “sudo parted -s /dev/sdb1”, which says, that the file or directory was not found.
As my OSMC isn’t able to boot atm, I’m performing the Linuxcommands on my MacBook w/ Linux Mint installed on it… That’s why the OSMC specific command didn’t work
Does not look good. If parted is not giving you output, it may not be detecting a partition table. Try fdisk /dev/sdb as a last shot. Othewise, the USB seems to have corrupted.
Okay… I made a mistake yesterday - I’m sorry (it was late…). I forgot the “print”-parameter for “parted -s”.
I corrected that: “sudo parted -s /dev/sdb print” gives following output:
Error: Can't have a partition outside the disk!
I also used fdisk. It goes to interactive mode if I use “sudo fdisk /dev/sdb”. So to get an output for you I tried “sudo fdisk -l /dev/sdb”. Here’s the output:
Disk /dev/sdb: 2 MB, 2097152 bytes
186 heads, 19 sectors/track, 1 cylinders, total 4096 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00049ab8
Device Boot Start End Blocks Id System
/dev/sdb1 4096 7819263 3907584 83 Linux
The partition table is broken. You will probably not have much luck here. We can try and reconstruct the partition layout, but I can’t guarantee the end of the partition.
*** No support. Use at own risk ***
Download my partition layout I have created for you here:
Hi Sam,
unfortunately this didn’t work. I copied the image on my USB stick successfully, but it’s still not working. I’m going to set up OSMC new for now. I hope the problem doesn’t appear again.
