Hi there
Hope some one can help
I have successfully setup OSMC on a Rasberrypi 2 B… and its working well.
I have used win32SD xxx to clone an image of the microsd card to use in a 2nd Rassberry Pi 2 B
I tested the newly cloned card in the original unit and it works fine,
I have purchased a second Rasberrypi 2 B and have installed the cloned sd card.
The Rasberrypi appears to boots up fine, I can access it through PUTTY,
But I am not getting any output on the HDMI port
Using Putty I have setup a wireless USB card. on this unit as well - working fine
But no picture on the HDMI?
Any ideas on what I can do to activate the HDMI port?
Thanks in advance
