I have searched the web and the forums and i just cant find an answer to my problem. Ive purchased an Raspberry pi 3 osmc with a Hauppauge WinTV-HVR-950Q. Below is some info for the OSMC running along with proof that my raspberry pi can see my WinTV-HVR-950Q
Kernel:
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 4.4.27-5-osmc (root@vero2a) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Tue Nov 22 02:23:12 UTC 2016
[ 2.062157] usb usb1: Manufacturer: Linux 4.4.27-5-osmc dwc_otg_hcd
[ 5.603416] media: Linux media interface: v0.10
[ 5.642319] Linux video capture interface: v2.00
USB info:
[ 2.148382] usbhid: USB HID core driver
[ 2.437276] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.637589] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.637615] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.917278] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.017620] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.017647] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.080850] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:88:e3:77
[ 3.157251] usb 1-1.5: new high-speed USB device number 4 using dwc_otg
[ 3.279663] usb 1-1.5: New USB device found, idVendor=2040, idProduct=7200
[ 3.279690] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=10
[ 3.279703] usb 1-1.5: Product: WinTV HVR-950
[ 3.279714] usb 1-1.5: Manufacturer: Hauppauge
[ 3.279724] usb 1-1.5: SerialNumber: 4032694906
[ 6.887486] usb 1-1.5: DVB: registering adapter 0 frontend 0 (Auvitek AU8522 QAM/8VSB Frontend)…
[ 7.177916] input: au0828 IR (Hauppauge HVR950Q) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/rc/rc0/input2
[ 7.180468] rc0: au0828 IR (Hauppauge HVR950Q) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/rc/rc0
[ 7.219049] usbcore: registered new interface driver au0828
[ 7.364172] usbcore: registered new interface driver snd-usb-audio
[ 23.720805] usb 1-1.5: DVB: adapter 0 frontend 0 frequency 0 out of range (54000000…858000000)
I’ve installed tvheadend with the latest version “Build: 4.0.9”
I’ve configured TVheadend per suggestions configured on the net and i cant seem to get past the follwoing message. “scan no data, failed” so i’m not getting any of my any of my channels to subscribe. below is the message when scanning through ATSC frequencies.
2016-12-17 23:00:28.001 mpegts: 653.028MHz in HauppaugeTv_ATSC_center_frequencies - tuning on Auvitek AU8522 QAM/8VSB Frontend : ATSC #0
2016-12-17 23:00:28.002 subscription: 01B1: “scan” subscribing to mux “653.028MHz”, weight: 2, adapter: “Auvitek AU8522 QAM/8VSB Frontend : ATSC #0”, network: “HauppaugeTv_ATSC_center_frequencies”, service: "Raw PID Subscription"
2016-12-17 23:00:33.000 mpegts: 653.028MHz in HauppaugeTv_ATSC_center_frequencies - scan no data, failed
2016-12-17 23:00:33.000 subscription: 01B1: “scan” unsubscribing
I hope that this is enough information to get a quick solution. Ultimately i would like to connect to existing Comcast cable, but would be happy with getting overt the air channels. Ive gone through updating drivers to trying different distributions with the same outcome so im leading to belive that i’m missing something but i cant figure what. So any helpful suggestion would really be appreciated.
