Osmc Power options
I use estuary skin. In Power options the first command is Exit and using that command osmc apparently close down and immediately reopen. For closing it down I have to use the 2nd command Power off system.
Is this normal? What is the “Exit” command used for?
Exit is used if you want to exit out of Kodi and then log in to the underlying GNU/Linux operating system, you would need a keyboard attached for this and when the screen goes blank if you press a key on the keyboard you’ll see a logon prompt, if the user doesn’t log on within a short period then Kodi restarts to prevent the user being stranded.
Thank you for the explanation.
