Hello,
I’ve installed a OSMC RC3 0.9.9 i try to use with a dongle USB Wifi TL-WN725N
With uname -a
Linux osmc 3.18.13-1-osmc #1 SMP PREEMPT Sun May 17 18:50:26 UTC 2015 armv7l GNU/Linux
i’ve tried to put the right driver but i guess i’ve failed…
Strarting without ethernet connected doesnt make the menu appear
What can i do to get out of this ?
Thanks for your help
Bernard
What did you try to do for the driver ?
If the wireless menu does not appear, it means a driver for the wireless adaptor did not load - eg the adaptor is not supported by the current kernel.
Your subject implies that it was previously working - what version of OSMC was it working on ?
Please provide your debug logs, at a minimum systemd journal and dmesg.
I’ve reinstalled from scratch and now it works.
