Hello all,
I just installed, downloaded from the osmc.tv website, the OSMC RC2 on a Raspberry B+.
After the system installs itself on the SD card I get the question to input my country.
I am not able to scroll up with the mouse, I can only scroll down with the mouse.
I use an wireless Logitech M150 mouse.
I use this mouse also on the Raspbmc KODI 14 media player with no trouble at all.
So I did an upgrade to the latest version using the sudo apt-get update: sudo apt-get upgrade command.
But this doesn’t solves the problem.
Also the System entry in the main menu window is not visible.
The following entry’s are visible:
Videos
Music
Pictures
My OSMC
Favourites
Programs
How can the System entry been made visible?
I seems if the system can’t cope with this mouse at the moment.
Is there a solution for the problem?
