Recently ripped my 4K copy of Die hard for OSMC. Plays back fine on my Mac. Despite being correctly scraped, the movie doesn’t show up in my OSMC library. When I manually navigate to it in videos>files, it says “no information found!”, then crashes as soon as I dismiss the dialog box (frowning face)
Tried playing back several times and the issue was consistent.
Running off of a Vero 4K+ with the latest release version of OSMC
Media info:
Summary
General
Unique ID : 215157630451336067286172623993688412137 (0xA1DDDA31F80220E269D1AD555D19CFE9)
Complete name : /Volumes/MovieLibrary/Die Hard (1988)/Die Hard (1988).mkv
Format : Matroska
Format version : Version 2
File size : 47.2 GiB
Duration : 2h 12mn
Overall bit rate : 51.1 Mbps
Movie name : Die Hard
Encoded date : UTC 2020-01-02 17:32:59
Writing application : MakeMKV v1.14.7 darwin(x64-release)
Writing library : libmakemkv v1.14.7 (1.3.5/1.4.7) darwin(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2h 12mn
Bit rate : 45.9 Mbps
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.231
Stream size : 42.4 GiB (90%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Original source medium : Blu-ray
Audio #1
ID in the original source medium : 4365 (0x110D)
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Duration : 2h 12mn
Bit rate mode : Variable
Bit rate : 3 672 Kbps
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 KHz
Frame rate : 93.750 fps (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 3.39 GiB (7%)
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
Audio #2
Format : DTS
Codec ID : A_DTS
Duration : 2h 12mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.39 GiB (3%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:02:21.099 : en:Chapter 02
00:03:57.487 : en:Chapter 03
00:05:11.936 : en:Chapter 04
00:06:09.827 : en:Chapter 05
00:07:50.928 : en:Chapter 06
00:11:57.842 : en:Chapter 07
00:13:17.922 : en:Chapter 08
00:14:03.092 : en:Chapter 09
00:14:17.982 : en:Chapter 10
00:16:58.308 : en:Chapter 11
00:21:00.467 : en:Chapter 12
00:22:41.610 : en:Chapter 13
00:24:53.241 : en:Chapter 14
00:26:50.108 : en:Chapter 15
00:28:49.936 : en:Chapter 16
00:33:24.460 : en:Chapter 17
00:34:08.337 : en:Chapter 18
00:35:26.415 : en:Chapter 19
00:38:18.337 : en:Chapter 20
00:42:33.217 : en:Chapter 21
00:43:24.143 : en:Chapter 22
00:45:18.424 : en:Chapter 23
00:47:59.293 : en:Chapter 24
00:52:39.030 : en:Chapter 25
00:56:49.155 : en:Chapter 26
00:57:55.221 : en:Chapter 27
00:58:38.723 : en:Chapter 28
01:00:49.479 : en:Chapter 29
01:01:38.861 : en:Chapter 30
01:04:18.396 : en:Chapter 31
01:07:43.893 : en:Chapter 32
01:11:58.605 : en:Chapter 33
01:12:58.290 : en:Chapter 34
01:19:14.708 : en:Chapter 35
01:26:10.665 : en:Chapter 36
01:28:49.782 : en:Chapter 37
01:29:27.236 : en:Chapter 38
01:30:06.651 : en:Chapter 39
01:35:43.195 : en:Chapter 40
01:38:57.973 : en:Chapter 41
01:41:26.747 : en:Chapter 42
01:45:24.234 : en:Chapter 43
01:47:44.708 : en:Chapter 44
01:48:10.734 : en:Chapter 45
01:49:49.958 : en:Chapter 46
01:51:09.412 : en:Chapter 47
01:54:16.015 : en:Chapter 48
01:58:22.512 : en:Chapter 49
01:59:44.260 : en:Chapter 50
02:02:00.604 : en:Chapter 51
02:03:48.671 : en:Chapter 52
02:05:13.130 : en:Chapter 53
02:06:28.122 : en:Chapter 54
02:07:19.423 : en:Chapter 55
logs:
https://paste.osmc.tv/ujijoficuz
Tried to post the full thing but it was far too long, cut it down to the relevant end section below:
Summary
Logs created on: 2020-01-10 12:57:26 - (Uptime = 516.45)
CGUITextureManager::GetTexturePath: could not find texture ‘OverlayUnwatched.png’
2020-01-10 12:52:04.859 T:3435057888 DEBUG: Previous line repeats 4 times.
2020-01-10 12:52:04.860 T:3435057888 DEBUG: ffmpeg[CCBED2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:04.863 T:3418272480 DEBUG: ffmpeg[CBBEB2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:04.868 T:3409879776 DEBUG: ffmpeg[CB3EA2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:04.871 T:3426665184 DEBUG: ffmpeg[CC3EC2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:04.880 T:4068618240 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture ‘OverlayUnwatched.png’
2020-01-10 12:52:04.882 T:3435057888 DEBUG: Previous line repeats 1 times.
2020-01-10 12:52:04.882 T:3435057888 DEBUG: ffmpeg[CCBED2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:04.882 T:4068618240 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture ‘OverlayUnwatched.png’
2020-01-10 12:52:04.889 T:3418272480 DEBUG: ffmpeg[CBBEB2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:04.899 T:3409879776 DEBUG: ffmpeg[CB3EA2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:04.902 T:3435057888 DEBUG: ffmpeg[CCBED2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:04.904 T:3426665184 DEBUG: ffmpeg[CC3EC2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:04.925 T:3418272480 DEBUG: ffmpeg[CBBEB2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:04.926 T:3435057888 DEBUG: ffmpeg[CCBED2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:04.941 T:3391652576 DEBUG: Thread Timer 3391652576 terminating
2020-01-10 12:52:04.946 T:4068618240 DEBUG: Keyboard: scancode: 0x6d, sym: 0x0119, unicode: 0x0000, modifier: 0x0
2020-01-10 12:52:04.979 T:3824911072 INFO: : QUERYING DATABASE
2020-01-10 12:52:06.174 T:3391652576 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 4 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
2020-01-10 12:52:06.955 T:4038062816 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 50ms
2020-01-10 12:52:06.956 T:3469923040 DEBUG: Thread Timer start, auto delete: false
2020-01-10 12:52:06.962 T:4068618240 DEBUG: Keyboard: scancode: 0x6d, sym: 0x0119, unicode: 0x0000, modifier: 0x0
2020-01-10 12:52:06.962 T:4068618240 DEBUG: HandleKey: pagedown (0xf085) pressed, action is PageDown
2020-01-10 12:52:06.964 T:4068618240 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture ‘OverlayUnwatched.png’
2020-01-10 12:52:06.982 T:3418272480 DEBUG: Previous line repeats 4 times.
2020-01-10 12:52:06.982 T:3418272480 DEBUG: ffmpeg[CBBEB2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:06.986 T:3824911072 INFO: : QUERYING DATABASE
2020-01-10 12:52:06.992 T:4068618240 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture ‘OverlayUnwatched.png’
2020-01-10 12:52:06.995 T:3435057888 DEBUG: Previous line repeats 3 times.
2020-01-10 12:52:06.995 T:3435057888 DEBUG: ffmpeg[CCBED2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:07.009 T:3426665184 DEBUG: ffmpeg[CC3EC2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:07.017 T:3435057888 DEBUG: ffmpeg[CCBED2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:07.019 T:3418272480 DEBUG: ffmpeg[CBBEB2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:07.038 T:3469923040 DEBUG: Thread Timer 3469923040 terminating
2020-01-10 12:52:07.062 T:4068618240 DEBUG: Keyboard: scancode: 0x6d, sym: 0x0119, unicode: 0x0000, modifier: 0x0
2020-01-10 12:52:07.168 T:3426665184 DEBUG: ffmpeg[CC3EC2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:07.170 T:3435057888 DEBUG: ffmpeg[CCBED2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:07.174 T:3409879776 DEBUG: ffmpeg[CB3EA2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:07.186 T:3418272480 DEBUG: ffmpeg[CBBEB2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:07.186 T:3426665184 DEBUG: ffmpeg[CC3EC2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:07.196 T:3435057888 DEBUG: ffmpeg[CCBED2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:07.209 T:3435057888 DEBUG: GetImageHash - unable to stat url smb://10.0.1.126/MovieLibrary4/Dunkirk (2017)/thumb.jpg
2020-01-10 12:52:08.382 T:4038062816 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 50ms
2020-01-10 12:52:08.383 T:3329241824 DEBUG: Thread Timer start, auto delete: false
2020-01-10 12:52:08.401 T:4068618240 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
2020-01-10 12:52:08.401 T:4068618240 DEBUG: HandleKey: down (0xf081) pressed, action is Down
2020-01-10 12:52:08.401 T:4017091296 INFO: CActiveAESink::OpenSink - initialize sink
2020-01-10 12:52:08.401 T:4017091296 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:hdmi:CARD=AMLM8AUDIO,DEV=0
2020-01-10 12:52:08.402 T:4017091296 INFO: CAESinkALSA::Initialize - Requested layout: FL, FR
2020-01-10 12:52:08.402 T:4017091296 INFO: CAESinkALSA::Initialize - set digital_codec 0
2020-01-10 12:52:08.402 T:4017091296 DEBUG: CAESinkALSA::Initialize – unmuting HDMI
2020-01-10 12:52:08.402 T:4017091296 INFO: CAESinkALSA::Initialize - Attempting to open device “@:CARD=AMLM8AUDIO,DEV=0”
2020-01-10 12:52:08.404 T:4068618240 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture ‘OverlayUnwatched.png’
2020-01-10 12:52:08.408 T:4017091296 INFO: CAESinkALSA::Initialize - Opened device “sysdefault:CARD=AMLM8AUDIO”
2020-01-10 12:52:08.409 T:4017091296 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2020-01-10 12:52:08.409 T:4017091296 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
2020-01-10 12:52:08.409 T:4017091296 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 8192
2020-01-10 12:52:08.410 T:4017091296 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 8192
2020-01-10 12:52:08.410 T:4017091296 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 186 ms
2020-01-10 12:52:08.411 T:4017091296 INFO: CAESinkALSA::Initialize - setting default aud_ch to 0
2020-01-10 12:52:08.411 T:4017091296 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2
2020-01-10 12:52:08.411 T:4017091296 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL, FR
2020-01-10 12:52:08.411 T:4017091296 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL, FR (ALSA: none) (CEA: 0)
2020-01-10 12:52:08.411 T:4017091296 DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
2020-01-10 12:52:08.411 T:4017091296 DEBUG: Output Device : AML-M8AUDIO
2020-01-10 12:52:08.411 T:4017091296 DEBUG: Sample Rate : 44100
2020-01-10 12:52:08.411 T:4017091296 DEBUG: Sample Format : AE_FMT_S32NE
2020-01-10 12:52:08.411 T:4017091296 DEBUG: Channel Count : 2
2020-01-10 12:52:08.411 T:4017091296 DEBUG: Channel Layout: FL, FR
2020-01-10 12:52:08.411 T:4017091296 DEBUG: Frames : 2048
2020-01-10 12:52:08.411 T:4017091296 DEBUG: Frame Size : 8
2020-01-10 12:52:08.465 T:3329241824 DEBUG: Thread Timer 3329241824 terminating
2020-01-10 12:52:08.479 T:4068618240 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
2020-01-10 12:52:08.538 T:3418272480 DEBUG: ffmpeg[CBBEB2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:09.001 T:3824911072 INFO: : QUERYING DATABASE
2020-01-10 12:52:09.024 T:4038062816 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 50ms
2020-01-10 12:52:09.024 T:3478315744 DEBUG: Thread Timer start, auto delete: false
2020-01-10 12:52:09.032 T:4068618240 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
2020-01-10 12:52:09.032 T:4068618240 DEBUG: HandleKey: right (0xf083) pressed, action is Right
2020-01-10 12:52:09.033 T:4068618240 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture ‘OverlayUnwatched.png’
2020-01-10 12:52:09.056 T:3426665184 DEBUG: ffmpeg[CC3EC2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:09.107 T:3478315744 DEBUG: Thread Timer 3478315744 terminating
2020-01-10 12:52:09.113 T:4068618240 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
2020-01-10 12:52:09.315 T:4038062816 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 50ms
2020-01-10 12:52:09.316 T:3329213152 DEBUG: Thread Timer start, auto delete: false
2020-01-10 12:52:09.332 T:4068618240 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
2020-01-10 12:52:09.332 T:4068618240 DEBUG: HandleKey: right (0xf083) pressed, action is Right
2020-01-10 12:52:09.362 T:3409879776 DEBUG: ffmpeg[CB3EA2E0]: [swscaler] No accelerated colorspace conversion found from yuv420p to bgra.
2020-01-10 12:52:09.374 T:3329213152 DEBUG: Thread Timer 3329213152 terminating
2020-01-10 12:52:09.385 T:4068618240 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
2020-01-10 12:52:09.713 T:4038062816 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 50ms
2020-01-10 12:52:09.713 T:3469923040 DEBUG: Thread Timer start, auto delete: false
2020-01-10 12:52:09.716 T:4068618240 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
2020-01-10 12:52:09.821 T:3469923040 DEBUG: Thread Timer 3469923040 terminating
2020-01-10 12:52:09.829 T:4068618240 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
2020-01-10 12:52:09.830 T:4068618240 DEBUG: HandleKey: return (0xf00d) pressed, action is Select
2020-01-10 12:52:09.830 T:4068618240 DEBUG: CGUIMediaWindow::GetDirectory (smb://10.0.1.126/MovieLibrary/Die Hard (1988)/)
2020-01-10 12:52:09.831 T:4068618240 DEBUG: ParentPath = [multipath://smb%3a%2f%2f10.0.1.126%2fMovieLibrary%2f/smb%3a%2f%2f10.0.1.126%2fMovieLibrary2%2f/smb%3a%2f%2f10.0.1.126%2fMovieLibrary3%2f/smb%3a%2f%2f10.0.1.126%2fMovieLibrary4%2f/]
2020-01-10 12:52:09.831 T:3469923040 DEBUG: Thread waiting start, auto delete: false
2020-01-10 12:52:09.875 T:3469923040 DEBUG: Thread waiting 3469923040 terminating
2020-01-10 12:52:09.897 T:3469923040 DEBUG: Thread BackgroundLoader start, auto delete: false
2020-01-10 12:52:09.905 T:4068618240 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture ‘OverlayUnwatched.png’
2020-01-10 12:52:09.919 T:3418272480 DEBUG: DoWork - trying to extract thumb from video file smb://10.0.1.126/MovieLibrary/Die Hard (1988)/._Die Hard (1988).mkv
2020-01-10 12:52:09.920 T:3469923040 DEBUG: Thread BackgroundLoader 3469923040 terminating
2020-01-10 12:52:09.923 T:3418272480 DEBUG: CFileCache::Open - opening <MovieLibrary/Die Hard (1988)/._Die Hard (1988).mkv> using cache
2020-01-10 12:52:09.926 T:3418272480 DEBUG: CSMBFile::Open - opened smb://USERNAME:PASSWORD@10.0.1.126/MovieLibrary/Die Hard (1988)/._Die Hard (1988).mkv, fd=10000
2020-01-10 12:52:09.930 T:3469923040 DEBUG: Thread FileCache start, auto delete: false
2020-01-10 12:52:09.935 T:3469923040 INFO: CFileCache::Process - Source read didn’t return any data! Hit eof(?)
2020-01-10 12:52:09.986 T:3418272480 DEBUG: ffmpeg[CBBEB2E0]: Format matroska,webm detected only with low score of 1, misdetection possible!
2020-01-10 12:52:09.986 T:3418272480 DEBUG: Open - probing detected format [matroska,webm]
2020-01-10 12:52:09.986 T:3418272480 ERROR: ffmpeg[CBBEB2E0]: [matroska,webm] Read error at pos. 1 (0x1)
2020-01-10 12:52:09.986 T:3418272480 ERROR: ffmpeg[CBBEB2E0]: [matroska,webm] EBML header parsing failed
2020-01-10 12:52:09.986 T:3418272480 ERROR: Open - Error, could not open file smb://10.0.1.126/MovieLibrary/Die Hard (1988)/._Die Hard (1988).mkv
2020-01-10 12:52:09.986 T:3418272480 ERROR: ExtractThumb - Error creating demuxer
2020-01-10 12:52:09.986 T:3469923040 DEBUG: Thread FileCache 3469923040 terminating
2020-01-10 12:52:09.987 T:3418272480 DEBUG: CSMBFile::Close closing fd 10000
2020-01-10 12:52:10.008 T:3824911072 INFO: : QUERYING DATABASE
2020-01-10 12:52:10.443 T:3391652576 NOTICE: script.module.metadatautils --> Rate limiter active for themoviedb.org - delaying request with 5 seconds - Configure a personal API key in the settings to get rid of this message and the delay.
2020-01-10 12:52:10.729 T:4038062816 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 50ms
2020-01-10 12:52:10.729 T:3478827744 DEBUG: Thread Timer start, auto delete: false
2020-01-10 12:52:10.762 T:4068618240 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
2020-01-10 12:52:10.836 T:3478827744 DEBUG: Thread Timer 3478827744 terminating
2020-01-10 12:52:10.845 T:4068618240 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
2020-01-10 12:52:10.846 T:4068618240 DEBUG: HandleKey: return (0xf00d) pressed, action is Select
2020-01-10 12:52:10.860 T:4068618240 DEBUG: CSMBFile::Open - opened smb://USERNAME:PASSWORD@10.0.1.126/MovieLibrary/Die Hard (1988)/movie.nfo, fd=10000
2020-01-10 12:52:10.868 T:4068618240 DEBUG: CSMBFile::Close closing fd 10000
2020-01-10 12:52:10.887 T:4068618240 DEBUG: VideoInfoScanner: Found matching full NFO file: smb://10.0.1.126/MovieLibrary/Die Hard (1988)/movie.nfo
2020-01-10 12:52:10.893 T:4068618240 DEBUG: DialogProgress::Open called
2020-01-10 12:52:10.893 T:4068618240 DEBUG: ------ Window Init (DialogConfirm.xml) ------
2020-01-10 12:52:11.016 T:3824911072 INFO: : QUERYING DATABASE
2020-01-10 12:52:11.102 T:4068618240 DEBUG: ExcludeFileOrFolder: File ‘stack://smb://10.0.1.126/MovieLibrary/Die Hard (1988)/._Die Hard (1988).mkv , smb://10.0.1.126/MovieLibrary/Die Hard (1988)/Die Hard (1988).mkv’ excluded. (Matches exclude rule RegExp: ‘[/]._’)
2020-01-10 12:52:11.103 T:4068618240 DEBUG: ------ Window Init (DialogConfirm.xml) ------
2020-01-10 12:52:11.103 T:4068618240 INFO: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2020-01-10 12:52:11.327 T:4068618240 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
2020-01-10 12:52:32.616 T:4038062816 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 50ms
2020-01-10 12:52:32.616 T:3391652576 DEBUG: Thread Timer start, auto delete: false
2020-01-10 12:52:32.623 T:4068618240 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
2020-01-10 12:52:32.673 T:3391652576 DEBUG: Thread Timer 3391652576 terminating
2020-01-10 12:52:32.707 T:4068618240 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
2020-01-10 12:52:32.707 T:4068618240 DEBUG: HandleKey: return (0xf00d) pressed, action is Select
2020-01-10 12:52:32.708 T:4017091296 INFO: CActiveAESink::OpenSink - initialize sink
2020-01-10 12:52:32.708 T:4017091296 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:hdmi:CARD=AMLM8AUDIO,DEV=0
2020-01-10 12:52:32.708 T:4017091296 INFO: CAESinkALSA::Initialize - Requested layout: FL, FR
2020-01-10 12:52:32.708 T:4017091296 INFO: CAESinkALSA::Initialize - set digital_codec 0
2020-01-10 12:52:32.708 T:4017091296 DEBUG: CAESinkALSA::Initialize – unmuting HDMI
2020-01-10 12:52:32.708 T:4017091296 INFO: CAESinkALSA::Initialize - Attempting to open device “@:CARD=AMLM8AUDIO,DEV=0”
2020-01-10 12:52:32.713 T:4017091296 INFO: CAESinkALSA::Initialize - Opened device “sysdefault:CARD=AMLM8AUDIO”
2020-01-10 12:52:32.715 T:4017091296 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2020-01-10 12:52:32.715 T:4017091296 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
2020-01-10 12:52:32.715 T:4017091296 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 8192
2020-01-10 12:52:32.716 T:4017091296 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 8192
2020-01-10 12:52:32.717 T:4017091296 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 186 ms
2020-01-10 12:52:32.717 T:4017091296 INFO: CAESinkALSA::Initialize - setting default aud_ch to 0
2020-01-10 12:52:32.717 T:4017091296 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2
2020-01-10 12:52:32.718 T:4017091296 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL, FR
2020-01-10 12:52:32.718 T:4017091296 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL, FR (ALSA: none) (CEA: 0)
2020-01-10 12:52:32.718 T:4017091296 DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
2020-01-10 12:52:32.718 T:4017091296 DEBUG: Output Device : AML-M8AUDIO
2020-01-10 12:52:32.718 T:4017091296 DEBUG: Sample Rate : 44100
2020-01-10 12:52:32.718 T:4017091296 DEBUG: Sample Format : AE_FMT_S32NE
2020-01-10 12:52:32.718 T:4017091296 DEBUG: Channel Count : 2
2020-01-10 12:52:32.718 T:4017091296 DEBUG: Channel Layout: FL, FR
2020-01-10 12:52:32.718 T:4017091296 DEBUG: Frames : 2048
2020-01-10 12:52:32.718 T:4017091296 DEBUG: Frame Size : 8
2020-01-10 12:52:32.938 T:4068618240 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
2020-01-10 12:52:32.941 T:4068618240 DEBUG: OnPlayMedia stack://smb://10.0.1.126/MovieLibrary/Die Hard (1988)/._Die Hard (1988).mkv , smb://10.0.1.126/MovieLibrary/Die Hard (1988)/Die Hard (1988).mkv
2020-01-10 12:52:32.952 T:4068618240 DEBUG: CFileCache::Open - opening <MovieLibrary/Die Hard (1988)/._Die Hard (1988).mkv> using cache
2020-01-10 12:52:32.956 T:4068618240 DEBUG: CSMBFile::Open - opened smb://USERNAME:PASSWORD@10.0.1.126/MovieLibrary/Die Hard (1988)/._Die Hard (1988).mkv, fd=10000
2020-01-10 12:52:32.960 T:3391652576 DEBUG: Thread FileCache start, auto delete: false
2020-01-10 12:52:32.964 T:3391652576 INFO: CFileCache::Process - Source read didn’t return any data! Hit eof(?)
2020-01-10 12:52:32.966 T:4068618240 DEBUG: ffmpeg[F2823000]: Format matroska,webm detected only with low score of 1, misdetection possible!
2020-01-10 12:52:32.966 T:4068618240 DEBUG: Open - probing detected format [matroska,webm]
2020-01-10 12:52:32.966 T:4068618240 ERROR: ffmpeg[F2823000]: [matroska,webm] Read error at pos. 1 (0x1)
2020-01-10 12:52:32.966 T:4068618240 ERROR: ffmpeg[F2823000]: [matroska,webm] EBML header parsing failed
2020-01-10 12:52:32.966 T:4068618240 ERROR: Open - Error, could not open file smb://10.0.1.126/MovieLibrary/Die Hard (1988)/._Die Hard (1988).mkv
2020-01-10 12:52:32.966 T:3391652576 DEBUG: Thread FileCache 3391652576 terminating
2020-01-10 12:52:32.966 T:4068618240 DEBUG: CSMBFile::Close closing fd 10000
---------------------- Kodi Old Log END --------------- 2qaAc90c
EDIT:
Solved! See end of thread.
