OSMC rpi 3 cannot connect to wifi 5GHz
OSMC rpi 2 connect withaut problem to wifi 5GHz with same wifi dongle
need to paste something into config.txt
sorry my English is not good
If you are trying to use an external wifi dongle on the pi3, you need to disable the internal one. You can do this by adding:
dtoverlay=sdhost
to the config.txt
Thanks Tom.
