OSMC Update Error
Then please provide debug enabled logs with trying to apply the Hotfix.
Alternatively if you are familiar with SSH you could apply the changes directly
For what it’s worth, I’ve solved this on the server side now so this won’t appear again.
I applied the hotfix today on the GUI as instructed and it worked right out of the box. It updated completely and sudo apt update also works from ssh.
I’m not familiar with SSH…
How do I access the command line on the Vero V?
Thanks… I’ll give it a go…
