OSMC update issues solution
Thanks,
I’ve no memory of doing that but as all seems to be working well I’ll leave well alone and wait for ‘Trixie’
:wink:
That’s fine – keep in mind that Trixie will require a manual reinstallation
I have the same message now, would love to help testing with Trixie, like always :slight_smile:
Sounds good, when there’s something to test that we’re happy with, I’ll make it available.
I’d recommend in the interim that you run the hotfix as pasted above.
There will be a stable update soon with some improvements.
I got the 64-bit warning. On a box with the aarch64 toolchain installed.
So I guess that means the new build won’t work on the 4+?
What…….i also have a V but the 4 still works just fine! :joy:
We ended support for the Vero 4K/4K+ last year.
We’ll keep a downloadable image on our website indefinitely but updates have indeed ceased.
FYI, my Vero V is unable to download the fix as site not reachable (getting a 403).
Applied it manually here and it works.
                                                File "/home/osmc/.kodi/addons/script.module.urllib3/lib/urllib3/connection.py", line 199, in \_new_conn
                                                   sock = connection.create_connection(
                                                 File "/home/osmc/.kodi/addons/script.module.urllib3/lib/urllib3/util/connection.py", line 60, in create_connection
                                                   for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
                                                 File "/usr/lib/python3.9/socket.py", line 953, in getaddrinfo
                                                   for res in \_socket.getaddrinfo(host, port, family, type, proto, flags):
                                               socket.gaierror: \[Errno -2\] Name or service not known
                                               The above exception was the direct cause of the following exception:
                                                 File "/home/osmc/.kodi/addons/script.module.urllib3/lib/urllib3/connectionpool.py", line 789, in urlopen
                                                   response = self.\_make_request(
                                                 File "/home/osmc/.kodi/addons/script.module.urllib3/lib/urllib3/connectionpool.py", line 495, in \_make_request
                                                   conn.request(
                                                 File "/home/osmc/.kodi/addons/script.module.urllib3/lib/urllib3/connection.py", line 441, in request
                                                   self.endheaders()
                                                 File "/usr/lib/python3.9/http/client.py", line 1274, in endheaders
                                                   self.\_send_output(message_body, encode_chunked=encode_chunked)
                                                 File "/usr/lib/python3.9/http/client.py", line 1034, in \_send_output
                                                   self.send(msg)
                                                 File "/usr/lib/python3.9/http/client.py", line 974, in send
                                                   self.connect()
                                                 File "/home/osmc/.kodi/addons/script.module.urllib3/lib/urllib3/connection.py", line 279, in connect
                                                   self.sock = self.\_new_conn()
                                                 File "/home/osmc/.kodi/addons/script.module.urllib3/lib/urllib3/connection.py", line 206, in \_new_conn
                                                   raise NameResolutionError(self.host, self, e) from e
                                               urllib3.exceptions.NameResolutionError: <urllib3.connection.HTTPConnection object at 0xc939ff88>: Failed to resolve 'mirrorservice.org' (\[Errno -2\] Name or service not known)                                               The above exception was the direct cause of the following exception:
                                                 File "/home/osmc/.kodi/addons/script.module.requests/lib/requests/adapters.py", line 486, in send
                                                   resp = conn.urlopen(
                                                 File "/home/osmc/.kodi/addons/script.module.urllib3/lib/urllib3/connectionpool.py", line 843, in urlopen
                                                   retries = retries.increment(
                                                 File "/home/osmc/.kodi/addons/script.module.urllib3/lib/urllib3/util/retry.py", line 519, in increment
                                                   raise MaxRetryError(\_pool, url, reason) from reason  # type: ignore\[arg-type\]
                                               urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='mirrorservice.org', port=80): Max retries exceeded with url: /sites/edge.samnazarko.co.uk/osmc/download/hotfixes/updates2026fix (Caused by NameResolutionError(“<urllib3.connection.HTTPConnection object at 0xc939ff88>: Failed to resolve ‘mirrorservice.org’ ([Errno -2] Name or service not known)”))                                               During handling of the above exception, another exception occurred:
                                                 File "/usr/share/kodi/addons/script.module.osmcsetting.updates//resources/lib/osmcupdates/osmc_hotfix.py", line 348, in <module>
                                                   hotfix = HotFix()
                                                 File "/usr/share/kodi/addons/script.module.osmcsetting.updates//resources/lib/osmcupdates/osmc_hotfix.py", line 45, in \__init_\_
                                                   hf_raw_text = self.retrieve_mirror_hotfix(hf_key)
                                                 File "/usr/share/kodi/addons/script.module.osmcsetting.updates//resources/lib/osmcupdates/osmc_hotfix.py", line 117, in retrieve_mirror_hotfix
                                                   raw_result = requests.get(url + hf_cypher)
                                                 File "/home/osmc/.kodi/addons/script.module.requests/lib/requests/api.py", line 73, in get
                                                   return request("get", url, params=params, \*\*kwargs)
                                                 File "/home/osmc/.kodi/addons/script.module.requests/lib/requests/api.py", line 59, in request
                                                   return session.request(method=method, url=url, \*\*kwargs)
                                                 File "/home/osmc/.kodi/addons/script.module.requests/lib/requests/sessions.py", line 589, in request
                                                   resp = self.send(prep, \*\*send_kwargs)
                                                 File "/home/osmc/.kodi/addons/script.module.requests/lib/requests/sessions.py", line 725, in send
                                                   history = \[resp for resp in gen\]
                                                 File "/home/osmc/.kodi/addons/script.module.requests/lib/requests/sessions.py", line 725, in <listcomp>
                                                 File "/home/osmc/.kodi/addons/script.module.requests/lib/requests/sessions.py", line 266, in resolve_redirects
                                                   resp = self.send(
                                                 File "/home/osmc/.kodi/addons/script.module.requests/lib/requests/sessions.py", line 703, in send
                                                   r = adapter.send(request, \*\*kwargs)
                                                 File "/home/osmc/.kodi/addons/script.module.requests/lib/requests/adapters.py", line 519, in send
                                                   raise ConnectionError(e, request=request)
                                               requests.exceptions.ConnectionError: HTTPConnectionPool(host='mirrorservice.org', port=80): Max retries exceeded with url: /sites/edge.samnazarko.co.uk/osmc/download/hotfixes/updates2026fix (Caused by NameResolutionError(“<urllib3.connection.HTTPConnection object at 0xc939ff88>: Failed to resolve ‘mirrorservice.org’ ([Errno -2] Name or service not known)”))–>End of Python script error report<–
So it’s a two step process. The initial instructions are misleading as it seems you only need to type text and click apply.
that was my impression also
Would need to see a full log to know what’s going on here.
Hi Sam,
just a question, with the new OS install to come, will there be any new “improvments” included in the next OS?
Of course,
But we already have some improvements (particularly Python performance) in the next update.
Is there anything you’re looking for in particular?
my vero 4k has been stuck on displaying ‘4/32 items –0 kBps – 1.5 / 21.4MB: 6%’ for a few days now
I applied the hotfix but nothing happened.
version OSMC May 2026 2026.05-1
Reboot then apply fix again
@starpony
Hi Sam,
ok, nothing in particular. Thanks for the reply.
@sam_nazarko Id like to volunteer for testing on debian trixie, is there some kind of document what you require of testers?
instructions on how to apply the hotfix via SSH would have helped me. i also found it easier to do via ssh (using vi), though the reasons why are a bit laughable.
I haven’t got any email yet, have you sent it out?
This should be a more prominent thing when going to the website. even in the communities forum it hardly pops out. :slight_smile:
also — I wonder whether in a future OSMC update it might be possible to put an alert up on the screen in the way the “update available” badge works now with custom directions (such as: open this website)
We’ve improved a lot of update functionality, but annoyingly, you have to update first..
Rest assured, it’s given us a lot to think about going forward.
Not yet, we will for the next stable update.
Vero 4K support ended in 2025.
You are running an unsupported version of OSMC which will break. I suggest you downgrade to the last official release. This update isn’t intended for unsupported devices.
