OSMC update issues solution
I wouldn’t be so sure about that. Debian dropped the bomb once with very short notice that they will drop support of a release to concentrate on another (I think it was debian 6 → 7). Needless to say that migrating all my servers at the time was a pain.
Also, even if the OSMC team is not that big, in a large company (1000+ people), they would be the ones owning the knowledge on how things work. The others are just corporate dead-weight.
This small team knows if a security patch/fix is required or not. And that, is the “essence” which makes this OSMC so valuable to me.
Unifi got caught off guard – so we weren’t the only ones.
But it is indeed time to move to Trixie.
Tried to apply the hotfix - got an “Add-on Error: Check Log for more info.”
Looking in the logs (/var/log/…) the only things from today are my logins and system boots. Where is the log file this error message is referring to?
If I manually edit the /etc/apt/sources.list and reboot, I finally get a useful error message.
Turns out my problem was that I had enabled the wired ethernet which was connected via a cross-over ethernet cable to my desktop computer, so I could get faster throughput copying movies to the Vero V using scp. But with that enabled (and not connected to the wider internet), the Vero quit even trying to fetch updates over WiFi, so everything was failing.
This is probably another weird-ass edge case, but I’ve transferred almost 8TB of video to the cute little video box so far, and hope, by the end of winter, to have another 8TB transferred, which will be all of the DVDs and BDs I have on one cute little box.
So thanks, and I don’t really need a response, but I wanted to mention I got into a head-scratcher of a situation with this. Perhaps there’s a place for putting an additional warning if two network interfaces are active, or perhaps there’s a better way to pick which one to use for downloading updates.
The kodi log at /home/osmc/.kodi/temp/kodi.log is meant afaIk.
Ok. Thanks. I think it was just complaining that it couldn’t find the internet, but I’ll check it later and follow up if there’s anything that looks useful in there.
This should not cause an issue.
Once Ethernet is up, we just start preferring that over WiFi.
The only thing I can think of is if that you were using a cross-over cable, you might have had a gateway conflict (ip route would show this).
The “network” on Ethernet was not routed, it was just a two-machine network for the purpose of transferring files. Pulling the cable probably would have cured the problem as well, but shutting off that interface solved it so I could update.
We take precedence on Ethernet, so that would explain it.
OK, got the update error a week or two ago. Tried again a few days ago, still. Came here, saw your post, ran the hotfix, voila, fixed. Thank you.
Got tech curious, decided to flatten my Vero V with one of the image files. Worked like a charm. That was too easy. Now I’m looking forward to the new build.
Glad this worked for you. FWIW: no need to reinstall OSMC – just the hotfix.
@sam_nazarko Can this be added to the start post or pinned please? The first post does say you can do it over SSH but doesn’t point out what should be done.
I added the needed info for someone wanting to edit it via the terminal since a few people have asked now. Hopefully @sam_nazarko is okay with me updating his post. I did not include full instructions as if someone doesn’t know how to make that edit from what was provided they really should be applying the hotfix instead.
That’s fine
I wonder why OSMC duplicated the Debian repository when just using the archived Debian versions should be fine. Details: https://archive.debian.org/debian/README
The archived repository was not online at the time and still is not resolving security updates.
Hey @sam_nazarko is this likely before the end of the year, or is it some time away?
Just trying to figure out whether I bother setting up a fresh Vero V that will be at a remote location now, or to wait. I’ll be deploying it around the end of the year. I’d rather not set it up only to find i need to wipe it and start again to move to Trixie between then and now :wink: would rather do it once.
Set up fresh if you want, a backup will work fine for restoring.
