about three months ago auto update on my VERO 4K+ stopped working. When I try to update manually, it shows following error:
Error installing:
Please report this on the OSMC forum.
Logs are available here: http://paste.osmc.tv/uwakodisod
Error installing:
I think you’ll need to fix this using the command line. Try these commands:
sudo apt-get update --allow-releaseinfo-change
If that seems to work, then run:
sudo apt-get dist-upgrade
