Sooo, just plugged mine into tv and after some booting up it gives only sad face and loops it up every 10 seconds.
What do i have to do? Thanks already.
Try plugging in a USB keyboard and when you see the sad face, press the ESC key. This should give you a login prompt.
Default userid is osmc and password is osmc.
When logged on, run the command grab-logs -A
and let us know the URL it gives.
Edit: If you don’t have network connection, use:
grab-logs -A -C
This will copy the log to /boot/uploadlog.txt.
Then you’ll need to insert a USB flash drive and run the command df
. The flash drive should appear as /media/xxxxxxx where xxxxxxxx is a label for the drive.
Then run
cp /boot/uploadlog.txt /media/xxxxxxx
sync
You can now move the flash drive to a PC. Please paste the contents of uploadlog.txt into http://paste.osmc.io and provide us the URL it returns.
I’m sorry to hear this.
Easiest solution, as you have nothing on the device, is to go to Download - OSMC and reinstall OSMC.
