Please, could someone explain why this video is jerky and out of sync (I’ve never had problems with my raspberry pi2 and osmc)
Here is my mediainfo: http://paste.osmc.io/sajunozezo.rib
Do you need also a log?
Ps. My media is on my NAS, NFS Shared as all the other videos
Format settings, GMC : 3 warppoints
See: Global motion compensation - Wikipedia
GMC failed to meet expectations of dramatic improvements in motion compensation, and as a result it was omitted from the H.264/MPEG-4 AVC
specification - designed as a successor to MPEG-4 ASP. Most of GMC’s
benefits could be obtained via better motion vector prediction.[1] GMC also represents a large computational cost during encoding which yields relatively minor quality improvements.
Due to the extra decoding CPU cost of global motion compensation,
most hardware players do not support global motion compensation.
So, no hardware decode for GMC with multiple warp points. It is possible over-clocking (or using a Pi3) would help.
Otherwise, re-encode it to use more standard encoding options.
Thank you very much for your reply
