Panasonic remote "Input" select
Have noticed an “issue” that has crept into CEC.
Was all fine until just after the RC release date.
If I have the TV set to OSMC as the source and then select another source via the AV button the source changes but it also brings up the Weather page.
With the original RC, changing the source via the AV button ONLY changed the source.
I have had that issue for about a year. Its probably a “version of CEC” thing.
Ok, thanks.
Strange - It’s only been doing it for me since just after the RC. Different CEC behaviour perhaps.
I wonder if it can be changed via remote.xml…
You should be able to remap the button
S
