Getting occasional sad face when changing channel.
Uploaded log: http://paste.osmc.io/otehixetet
Thanks.
Can you provide debug logs please.
To get a better understanding of the problem you are experiencing we need more information from you. Please see How to submit a useful support request - General - OSMC for advice on how to help us.
I’ve reproduced the fault after a reboot. Debug logging is on. Uploaded all logs via MyOsmc: ohefudufow
Don’t know if it’s of any use on another system but switching to channel 4 is what triggers the problem. Anything else I can do, please ask.
After a bit more testing, I can get to channel 4 by jumping to it when not in full screen ( when channel list is showing ). Once I’ve done this I can view any other channel that is on the same mux as channel 4, but all other channels then show only horizontal lines, like when the normal picture is stretched and twisted.
Seems to be related to muxes rather than individual channels.
I understand that it takes time to examine log files but can you say if the log files I uploaded are the ones you need?
Do you have the mpeg2 license installed?
With software decoding of mpeg2 streams, I have similar problems.
After installing the codec license, everything is fine.
Softwaredecoding mpeg2 might be a bit broken right now.
License arrived today and once installed, problems disappeared. Thanks.
