Powered off over night and … the 850MHz settings are back in config.txt defo a bug.
Is the overclock page hard coded ? … as the speed options do not reflect the current 1GHz setting.
Hello,
I was just wondering if a fix has been out in place for this bug yet? Just done a fresh install a few days ago (along with the update that came out last night), and I’ve noticed under My OSMC > Over clock, it says the default and current freq is 850. Am I just being stupid and reading it wrong?
Thank you for all your work, honestly (:
I’m not sure. I did add some code to detect Pi Zero but didn’t have one to test at hand. Ideally we want to step through the installer and see why this is happening
That’s not a problem. If you unable to get your hands on a P0, then I don’t mind being offering some time, if you don’t mind putting up with my sometimes silly questions.
