I was updating from the October build to the latest version which was only released a couple days ago.
My pi started freezing about a month ago, and last week the freezes had become very frequent (almost daily). These freezes would happen only if the system had been idle for more than a few hours. I figured updating could help with the issue but the update didn’t go as planned either.
Mid-way through the update. I got a bunch of errors and I’m quite sure it’s stuck now. I can ping it but can’t SSH. After the above-mentioned freezes, I wouldn’t be able to do either.
I did a hard-reset and surprisingly everything went back to the way it was. Literally everything. I ran fsck and configured the pi so it would force fsck at every boot.
I’m using the official power supply so I don’t think that’s the problem.
That being said, when I tried to update again through SSH using dist-upgrade, I got the same errors. One of the filesystem errors, this time, said “This should not happen! Data will be lost!”.
I’ll try to test the SD card on my mac and report back here.
Ah, there’s another catch. Once the first few errors pop up, I get a report saying that the volume is being mounted read-only. I assume that’s what allows me to revert to the previous version.
After rebooting though, I have been able to run apt-get update as well as dpkg so I’m pretty sure I can write onto the card.
Are those changes still there after a reboot?
Definetly suggest to do a image of the card and test the card with h2testw. If card OK you can write the image back. If H2testw fails you can dump the card.
Yeah. All the new packages are there. Skin changes too. I modified the menu for example, and every change was kept.
Pi seems to be back to the way it was: Daily freezes. When it freezes, I can’t SSH into or even ping the device. The SD LED never lights up, and all I see is the thermometer icon on a black screen. I’ve checked the logs but I really can’t see what could cause it to overheat. Again I emphasize this only happens when the device has been idle for a while (more than a few hours).
I looked at those threads. One user had a bad power supply, the other was overclocking, this guy had a library 370 subfolders deep… I have none of those problems. Nothing described in those threads applied to my pi which is why I opened this thread in the first place. Nothing in the few threads marked as solved helped me at all.
Also, I’ve been checking CPU usage throughout the week. Nothing unusual. Idles at 15% and the system is only under heavy load during library updates or just after boot.
Nope. I only see the thermometer icon after booting while everything starts up (or during a library update). Also, the pi never freezes in these scenarios. After a few idle hours, however, I see a black screen, an unresponsive pi and the thermometer.
I’m watching a 1080p video right now at 58 degrees.
