The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Oct 24 19:05:11 2015 from 192.168.0.99
osmc@osmc:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.2.1-1-osmc (root@vero) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Wed Sep 23 17:57:49 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 80a48440, node_mem_map ae156000
[ 0.000000] Normal zone: 1692 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9460->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 12 pages/cpu @ae118000 s19328 r8192 d21632 u49152
[ 0.000000] pcpu-alloc: s19328 r8192 d21632 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa01041 bcm2709.serial=0x34ece0be smsc95xx.macaddr=B8:27:EB:EC:E0:BE bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 742668K/770048K available (7748K kernel code, 550K rwdata, 1820K rodata, 412K init, 762K bss, 19188K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xaf800000 - 0xff000000 (1272 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80960324 (9569 kB)
.init : 0x80961000 - 0x809c8000 ( 412 kB)
.data : 0x809c8000 - 0x80a51aec ( 551 kB)
.bss : 0x80a54000 - 0x80b12a4c ( 763 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000032] Switching to timer-based delay loop, resolution 52ns
[ 0.000304] Console: colour dummy device 80x30
[ 0.000529] console [tty0] enabled
[ 0.000555] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000584] pid_max: default: 32768 minimum: 301
[ 0.000980] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001002] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002240] Initializing cgroup subsys blkio
[ 0.002283] Initializing cgroup subsys memory
[ 0.002322] Initializing cgroup subsys devices
[ 0.002347] Initializing cgroup subsys freezer
[ 0.002388] Initializing cgroup subsys net_cls
[ 0.002462] CPU: Testing write buffer coherency: ok
[ 0.002546] ftrace: allocating 19043 entries in 56 pages
[ 0.049072] CPU0: update cpu_capacity 1024
[ 0.049112] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.049129] [bcm2709_smp_prepare_cpus] enter
[ 0.049267] Setting up static identity map for 0x8240 - 0x8298
[ 0.078978] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.079337] [bcm2709_secondary_init] enter cpu:1
[ 0.079392] CPU1: update cpu_capacity 1024
[ 0.079401] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.088953] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.089237] [bcm2709_secondary_init] enter cpu:2
[ 0.089271] CPU2: update cpu_capacity 1024
[ 0.089280] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.098966] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.099219] [bcm2709_secondary_init] enter cpu:3
[ 0.099249] CPU3: update cpu_capacity 1024
[ 0.099257] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.099350] Brought up 4 CPUs
[ 0.099380] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.099391] CPU: All CPU(s) started in SVC mode.
[ 0.100391] devtmpfs: initialized
[ 0.123017] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.123548] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.124638] pinctrl core: initialized pinctrl subsystem
[ 0.125432] NET: Registered protocol family 16
[ 0.130869] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.158786] cpuidle: using governor ladder
[ 0.188816] cpuidle: using governor menu
[ 0.188951] bcm2709.uart_clock = 3000000
[ 0.196290] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.196310] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.196512] Serial: AMBA PL011 UART driver
[ 0.196832] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 0.197526] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.270536] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[ 0.270592] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[ 0.271698] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 0.271717] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 0.272302] SCSI subsystem initialized
[ 0.272544] usbcore: registered new interface driver usbfs
[ 0.272655] usbcore: registered new interface driver hub
[ 0.272823] usbcore: registered new device driver usb
[ 0.273592] raspberrypi-firmware soc:firmware: Attached to firmware from 2015-09-23 12:21
[ 0.300696] clocksource: Switched to clocksource arch_sys_counter
[ 0.351589] FS-Cache: Loaded
[ 0.352046] CacheFiles: Loaded
[ 0.368574] NET: Registered protocol family 2
[ 0.369813] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.369955] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.370148] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.370276] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.370341] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.370756] NET: Registered protocol family 1
[ 0.371361] RPC: Registered named UNIX socket transport module.
[ 0.371380] RPC: Registered udp transport module.
[ 0.371391] RPC: Registered tcp transport module.
[ 0.371402] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.371966] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.374516] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.374722] audit: initializing netlink subsys (disabled)
[ 0.374787] audit: type=2000 audit(0.349:1): initialized
[ 0.390143] VFS: Disk quotas dquot_6.6.0
[ 0.390526] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.393350] FS-Cache: Netfs 'nfs' registered for caching
[ 0.394506] NFS: Registering the id_resolver key type
[ 0.394581] Key type id_resolver registered
[ 0.394594] Key type id_legacy registered
[ 0.397533] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.397735] io scheduler noop registered
[ 0.398304] io scheduler bfq registered (default)
[ 0.398316] BFQ I/O-scheduler version: v7r7
[ 0.400863] BCM2708FB: allocated DMA memory eec00000
[ 0.400911] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.435112] Console: switching to colour frame buffer device 240x67
[ 0.457933] vc-cma: Videocore CMA driver
[ 0.457951] vc-cma: vc_cma_base = 0x00000000
[ 0.457964] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.457975] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.458276] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.476397] brd: module loaded
[ 0.486185] loop: module loaded
[ 0.487330] vchiq: vchiq_init_state: slot_zero = 0xaec80000, is_master = 0
[ 0.489199] Loading iSCSI transport class v2.0-870.
[ 0.490131] usbcore: registered new interface driver smsc95xx
[ 0.490206] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.690583] Core Release: 2.80a
[ 0.690621] Setting default values for core params
[ 0.690649] Finished setting default values for core params
[ 0.891111] Using Buffer DMA mode
[ 0.891129] Periodic Transfer Interrupt Enhancement - disabled
[ 0.891139] Multiprocessor Interrupt Enhancement - disabled
[ 0.891151] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.891168] Dedicated Tx FIFOs mode
[ 0.891609] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xaec14000 dma = 0xeec14000 len=9024
[ 0.891650] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 0.891675] dwc_otg: Microframe scheduler enabled
[ 0.891745] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x8054c124
[ 0.891767] WARN::hcd_init_fiq:413: FIQ ASM at 0x8054c494 length 36
[ 0.891787] WARN::hcd_init_fiq:438: MPHI regs_base at 0xaf89a000
[ 0.891839] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.891893] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.891947] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 0.892002] Init: Port Power? op_state=1
[ 0.892012] Init: Power Port (0)
[ 0.892329] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.892349] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.892365] usb usb1: Product: DWC OTG Controller
[ 0.892381] usb usb1: Manufacturer: Linux 4.2.1-1-osmc dwc_otg_hcd
[ 0.892396] usb usb1: SerialNumber: 3f980000.usb
[ 0.893576] hub 1-0:1.0: USB hub found
[ 0.893645] hub 1-0:1.0: 1 port detected
[ 0.894487] dwc_otg: FIQ enabled
[ 0.894502] dwc_otg: NAK holdoff enabled
[ 0.894513] dwc_otg: FIQ split-transaction FSM enabled
[ 0.894554] Module dwc_common_port init
[ 0.894902] usbcore: registered new interface driver usb-storage
[ 0.895285] mousedev: PS/2 mouse device common for all mice
[ 0.895881] usbcore: registered new interface driver usbtouchscreen
[ 0.896369] bcm2835-cpufreq: min=600000 max=900000
[ 0.899281] sdhci: Secure Digital Host Controller Interface driver
[ 0.899290] sdhci: Copyright(c) Pierre Ossman
[ 0.899648] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 0.899663] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 0.930812] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.931315] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.931460] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.931644] usbcore: registered new interface driver usbhid
[ 0.931653] usbhid: USB HID core driver
[ 0.931937] Initializing XFRM netlink socket
[ 0.931972] NET: Registered protocol family 17
[ 0.932108] Key type dns_resolver registered
[ 0.932290] Registering SWP/SWPB emulation handler
[ 0.937375] registered taskstats version 1
[ 0.937568] vc-sm: Videocore shared memory driver
[ 0.937583] [vc_sm_connected_init]: start
[ 0.940179] [vc_sm_connected_init]: end - returning 0
[ 0.942386] Waiting for root device /dev/mmcblk0p2...
[ 0.968370] mmc0: host does not support reading read-only switch, assuming write-enable
[ 0.970365] mmc0: new high speed SDHC card at address 0007
[ 0.971025] mmcblk0: mmc0:0007 SD16G 14.9 GiB
[ 0.972182] mmcblk0: p1 p2
[ 1.053788] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.053805] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.090817] Indeed it is in host mode hprt0 = 00021501
[ 1.270729] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.270886] Indeed it is in host mode hprt0 = 00001101
[ 1.471101] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.471126] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.471940] hub 1-1:1.0: USB hub found
[ 1.472059] hub 1-1:1.0: 5 ports detected
[ 1.750783] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.851114] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.851138] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.854046] smsc95xx v1.0.4
[ 1.914134] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:ec:e0:be
[ 2.150772] usb 1-1.4: new low-speed USB device number 4 using dwc_otg
[ 2.272205] usb 1-1.4: New USB device found, idVendor=1997, idProduct=1221
[ 2.272230] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.272241] usb 1-1.4: Product: Wireless Air mouse Keyboard
[ 2.272255] usb 1-1.4: Manufacturer:
[ 2.286979] input: Wireless Air mouse Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:1997:1221.0001/input/input0
[ 2.341811] hid-generic 0003:1997:1221.0001: input,hidraw0: USB HID v1.00 Keyboard [ Wireless Air mouse Keyboard] on usb-3f980000.usb-1.4/input0
[ 2.363164] input: Wireless Air mouse Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:1997:1221.0002/input/input1
[ 2.421293] hid-generic 0003:1997:1221.0002: input,hidraw1: USB HID v1.00 Mouse [ Wireless Air mouse Keyboard] on usb-3f980000.usb-1.4/input1
[ 5.409143] random: nonblocking pool is initialized
[ 7.030721] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 7.132534] usb 1-1.3: New USB device found, idVendor=067b, idProduct=2506
[ 7.132549] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 7.132562] usb 1-1.3: Product: Mass Storage Device
[ 7.132572] usb 1-1.3: Manufacturer: Prolific Technology Inc.
[ 7.132582] usb 1-1.3: SerialNumber: 0
[ 7.133492] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[ 7.133852] scsi host0: usb-storage 1-1.3:1.0
[ 8.166250] scsi 0:0:0:0: Direct-Access ST2000DM 001-1ER164 CC25 PQ: 0 ANSI: 0
[ 8.168274] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 8.168778] sd 0:0:0:0: [sda] Write Protect is off
[ 8.168796] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 8.169295] sd 0:0:0:0: [sda] No Caching mode page found
[ 8.169310] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 8.192526] sda: sda1 < sda5 >
[ 8.195231] sd 0:0:0:0: [sda] Attached SCSI disk
[ 13.974992] EXT4-fs (mmcblk0p2): recovery complete
[ 13.981466] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 13.981535] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 13.981680] devtmpfs: mounted
[ 13.982201] Freeing unused kernel memory: 412K (80961000 - 809c8000)
[ 15.486226] NET: Registered protocol family 10
[ 15.496850] systemd[1]: /etc/mtab is not a symlink or not pointing to /proc/self/mounts. This is not supported anymore. Please make sure to replace this file by a symlink to avoid incorrect or misleading mount(8) output.
[ 15.726768] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 15.726986] systemd[1]: Found ordering cycle on basic.target/start
[ 15.727008] systemd[1]: Found dependency on sysinit.target/start
[ 15.727028] systemd[1]: Found dependency on kbd.service/start
[ 15.727047] systemd[1]: Found dependency on remote-fs.target/start
[ 15.727064] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 15.727081] systemd[1]: Found dependency on connman.service/start
[ 15.727097] systemd[1]: Found dependency on dbus.service/start
[ 15.727113] systemd[1]: Found dependency on basic.target/start
[ 15.727130] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 15.727150] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 15.727418] systemd[1]: Found ordering cycle on basic.target/start
[ 15.727441] systemd[1]: Found dependency on sysinit.target/start
[ 15.727460] systemd[1]: Found dependency on rpcbind.service/start
[ 15.727479] systemd[1]: Found dependency on network-online.target/start
[ 15.727496] systemd[1]: Found dependency on network.target/start
[ 15.727512] systemd[1]: Found dependency on connman.service/start
[ 15.727529] systemd[1]: Found dependency on dbus.service/start
[ 15.727545] systemd[1]: Found dependency on basic.target/start
[ 15.727562] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 15.727581] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 15.816898] fuse init (API version 7.23)
[ 15.854606] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 15.991889] systemd-udevd[126]: starting version 215
[ 16.269170] bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate 100000)
[ 16.276541] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 16.406275] snd-hifiberry-digi sound: ASoC: CPU DAI (null) not registered
[ 16.406303] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 16.408400] snd-hifiberry-digi sound: ASoC: CODEC DAI wm8804-spdif not registered
[ 16.408425] snd-hifiberry-digi sound: snd_soc_register_card() failed: -517
[ 16.425306] wm8804 1-003b: revision E
[ 16.430364] snd-hifiberry-digi sound: wm8804-spdif <-> 3f203000.i2s mapping ok
[ 16.465581] usbcore: registered new interface driver uas
[ 16.476490] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 16.707244] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 17.614241] systemd-journald[107]: Received request to flush runtime journal from PID 1
[ 17.833308] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 17.833766] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 19.396869] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 19.398945] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[ 19.602546] 8021q: 802.1Q VLAN Support v1.8
[ 43.448930] Console: switching to colour dummy device 80x30
MOD EDIT: Please use the preformatted code tags for long runs of code
