## Bug report
### Describe the bug
Here is a clear and concise description of …what the problem is:
When calling a plugin via a JSON RPC request, if this call opens a dialog/window on kodi and you try to close it - without making any further JSON RPC requests - this dialog will open again and again (for at least 5 times). This happens on kodi 18.3 only. Works fine on 18.2.
When reading the logs, it seems that kodi is starting to rerun the request again and again
## Expected Behavior
Here is a clear and concise description of what was expected to happen:
It should not rerun the called request.
## Actual Behavior
Kodi rerun the called request.
### To Reproduce
Steps to reproduce the behavior:
1. Simply run this curl request:
```curl
curl -X POST \
http://127.0.0.1:8080/jsonrpc \
-H 'Content-Type: application/json' \
-H 'Host: 127.0.0.1:8080' \
-d '{"jsonrpc":"2.0","id":1,"method":"Player.Open","params":{"item":{"file":"plugin://plugin.video.youtube/fakeCallToDisplayAWindow"}}}
### Debuglog
The debuglog can be found here:
```txt
2019-07-19 13:38:17.228 T:4884227520 DEBUG: StartScript - calling plugin YouTube('plugin://plugin.video.youtube/fakeCallToDisplayAWindow','1','','resume:true')
2019-07-19 13:38:17.229 T:123145417240576 DEBUG: Thread LanguageInvoker start, auto delete: false
2019-07-19 13:38:17.229 T:123145417240576 INFO: initializing python engine.
2019-07-19 13:38:17.229 T:123145417240576 DEBUG: CPythonInvoker(19, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): start processing
2019-07-19 13:38:17.249 T:123145425747968 DEBUG: Thread scriptobs start, auto delete: false
2019-07-19 13:38:17.249 T:123145417240576 DEBUG: -->Python Interpreter Initialized<--
2019-07-19 13:38:17.249 T:123145417240576 DEBUG: CPythonInvoker(19, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): the source file to load is "/Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py"
2019-07-19 13:38:17.250 T:123145417240576 DEBUG: CPythonInvoker(19, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): setting the Python path to /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.certifi/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.chardet/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.idna/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.inputstreamhelper/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.kodi-six/libs:/Users/JB/Library/Application Support/Kodi/addons/script.module.requests/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.six/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.urllib3/lib:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/setuptools-18.4-py2.7.egg:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/Pillow-3.0.0-py2.7-macosx-10.14-x86_64.egg:/Applications/Kodi.app/Contents/Libraries:/Applications/Kodi.app/Contents/Libraries/lib/python27.zip:/Applications/Kodi.app/Contents/Libraries/lib/python2.7:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-darwin:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac/lib-scriptpackages:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-tk:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-old:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-dynload
2019-07-19 13:38:17.251 T:123145417240576 DEBUG: CPythonInvoker(19, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): entering source directory /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib
2019-07-19 13:38:17.251 T:123145417240576 DEBUG: CPythonInvoker(19, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): instantiating addon using automatically obtained id of "plugin.video.youtube" dependent on version 2.20.0 of the xbmc.python api
2019-07-19 13:38:17.450 T:4884227520 DEBUG: ------ Window Init (DialogBusy.xml) ------
2019-07-19 13:38:17.638 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:17.638 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:17.641 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:17.642 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:17.642 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:17.643 T:123145417240576 DEBUG: [plugin.video.youtube] send_notification: |check_settings| -> |{"httpd_address": "0.0.0.0", "use_httpd": false, "whitelist": "", "httpd_port": 50152}|
2019-07-19 13:38:17.643 T:123145417240576 DEBUG: [plugin.video.youtube] JSONStore Load |/Users/JB/Library/Application Support/Kodi/userdata/addon_data/plugin.video.youtube/api_keys.json|
2019-07-19 13:38:17.644 T:123145417240576 DEBUG: [plugin.video.youtube] JSONStore Load |/Users/JB/Library/Application Support/Kodi/userdata/addon_data/plugin.video.youtube/access_manager.json|
2019-07-19 13:38:17.645 T:123145419845632 DEBUG: CAnnouncementManager - Announcement: check_settings from plugin.video.youtube
2019-07-19 13:38:17.645 T:123145419845632 DEBUG: GOT ANNOUNCEMENT, type: 512, from plugin.video.youtube, message check_settings
2019-07-19 13:38:17.647 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:17.647 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:17.649 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:17.651 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:17.651 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:17.653 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:17.653 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:17.655 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:17.657 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:17.657 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:17.659 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:17.659 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:17.662 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:17.663 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:17.663 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:17.667 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:17.667 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:17.670 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:17.671 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:17.671 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:17.672 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.access_token) was not found.
2019-07-19 13:38:17.672 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.refresh_token) was not found.
2019-07-19 13:38:17.672 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.access_token.expires) was not found.
2019-07-19 13:38:17.672 T:123145417240576 DEBUG: CSettingsManager: requested setting (youtube.api.last.hash) was not found.
2019-07-19 13:38:17.672 T:123145417240576 DEBUG: [plugin.video.youtube] User: |0| Using API key set: |1|
2019-07-19 13:38:17.680 T:123145426821120 DEBUG: [plugin.video.youtube] onNotification: |check_settings| -> |{"httpd_address": "0.0.0.0", "use_httpd": false, "whitelist": "", "httpd_port": 50152}|
2019-07-19 13:38:17.680 T:123145417240576 DEBUG: [plugin.video.youtube] Starting Kodion framework by bromix...
2019-07-19 13:38:17.680 T:123145417240576 NOTICE: [plugin.video.youtube] Running: YouTube (6.5.0) on Leia (Kodi-18.3) with Python 2.7.15
Path: /fakeCallToDisplayAWindow
Params: {}
2019-07-19 13:38:17.681 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:17.681 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:17.684 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:17.685 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:17.685 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:17.692 T:123145417240576 ERROR: [plugin.video.youtube] Mapping for path '/fakeCallToDisplayAWindow' not found
2019-07-19 13:38:17.695 T:4884227520 DEBUG: ------ Window Init (DialogConfirm.xml) ------
2019-07-19 13:38:17.695 T:4884227520 INFO: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2019-07-19 13:38:17.715 T:123145426284544 DEBUG: Skin Helper Service --> Kodi_Monitor: sender plugin.video.youtube - method: Other.check_settings - data: ["%7B%22httpd_address%22%3A%20%220.0.0.0%22%2C%20%22use_httpd%22%3A%20false%2C%20%22whitelist%22%3A%20%22%22%2C%20%22httpd_port%22%3A%2050152%7D"]
2019-07-19 13:38:19.129 T:4884227520 INFO: CheckIdle - Closing session to http://api.themoviedb.org (easy=0x7f884299b400, multi=0x7f8849fa6f30)
2019-07-19 13:38:20.467 T:4884227520 DEBUG: ------ Window Init (Pointer.xml) ------
2019-07-19 13:38:21.655 T:4884227520 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
2019-07-19 13:38:21.662 T:123145417240576 DEBUG: [plugin.video.youtube] Shutdown of Kodion after |3.9828| seconds
2019-07-19 13:38:21.662 T:123145417240576 INFO: CPythonInvoker(19, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): script successfully run
2019-07-19 13:38:25.111 T:4884227520 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
2019-07-19 13:38:25.111 T:123145425747968 DEBUG: Thread scriptobs 123145425747968 terminating
2019-07-19 13:38:25.111 T:4884227520 DEBUG: WaitOnScriptResult- cancelling plugin YouTube (id=19)
2019-07-19 13:38:25.111 T:123145417240576 DEBUG: onExecutionDone(19, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py)
2019-07-19 13:38:25.122 T:123145417240576 INFO: Python interpreter interrupted by user
2019-07-19 13:38:25.122 T:4884227520 DEBUG: CPythonInvoker(19, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): script termination took 11ms
2019-07-19 13:38:25.122 T:123145417240576 DEBUG: Thread LanguageInvoker 123145417240576 terminating
2019-07-19 13:38:25.122 T:4884227520 DEBUG: StartScript - calling plugin YouTube('plugin://plugin.video.youtube/fakeCallToDisplayAWindow','2','','resume:true')
2019-07-19 13:38:25.122 T:123145417240576 DEBUG: Thread LanguageInvoker start, auto delete: false
2019-07-19 13:38:25.123 T:123145417240576 INFO: initializing python engine.
2019-07-19 13:38:25.123 T:123145417240576 DEBUG: CPythonInvoker(20, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): start processing
2019-07-19 13:38:25.139 T:123145417240576 DEBUG: -->Python Interpreter Initialized<--
2019-07-19 13:38:25.139 T:123145417240576 DEBUG: CPythonInvoker(20, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): the source file to load is "/Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py"
2019-07-19 13:38:25.140 T:123145417240576 DEBUG: CPythonInvoker(20, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): setting the Python path to /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.certifi/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.chardet/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.idna/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.inputstreamhelper/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.kodi-six/libs:/Users/JB/Library/Application Support/Kodi/addons/script.module.requests/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.six/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.urllib3/lib:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/setuptools-18.4-py2.7.egg:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/Pillow-3.0.0-py2.7-macosx-10.14-x86_64.egg:/Applications/Kodi.app/Contents/Libraries:/Applications/Kodi.app/Contents/Libraries/lib/python27.zip:/Applications/Kodi.app/Contents/Libraries/lib/python2.7:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-darwin:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac/lib-scriptpackages:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-tk:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-old:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-dynload
2019-07-19 13:38:25.140 T:123145417240576 DEBUG: CPythonInvoker(20, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): entering source directory /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib
2019-07-19 13:38:25.140 T:123145417240576 DEBUG: CPythonInvoker(20, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): instantiating addon using automatically obtained id of "plugin.video.youtube" dependent on version 2.20.0 of the xbmc.python api
2019-07-19 13:38:25.143 T:123145425747968 DEBUG: Thread scriptobs start, auto delete: false
2019-07-19 13:38:25.344 T:4884227520 DEBUG: ------ Window Init (DialogBusy.xml) ------
2019-07-19 13:38:25.461 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:25.461 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:25.464 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:25.465 T:4884227520 DEBUG: ------ Window Deinit (Pointer.xml) ------
2019-07-19 13:38:25.465 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:25.465 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:25.466 T:123145417240576 DEBUG: [plugin.video.youtube] send_notification: |check_settings| -> |{"httpd_address": "0.0.0.0", "use_httpd": false, "whitelist": "", "httpd_port": 50152}|
2019-07-19 13:38:25.466 T:123145417240576 DEBUG: [plugin.video.youtube] JSONStore Load |/Users/JB/Library/Application Support/Kodi/userdata/addon_data/plugin.video.youtube/api_keys.json|
2019-07-19 13:38:25.467 T:123145417240576 DEBUG: [plugin.video.youtube] JSONStore Load |/Users/JB/Library/Application Support/Kodi/userdata/addon_data/plugin.video.youtube/access_manager.json|
2019-07-19 13:38:25.470 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:25.470 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:25.472 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:25.473 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:25.473 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:25.476 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:25.476 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:25.478 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:25.479 T:123145419845632 DEBUG: CAnnouncementManager - Announcement: check_settings from plugin.video.youtube
2019-07-19 13:38:25.479 T:123145419845632 DEBUG: GOT ANNOUNCEMENT, type: 512, from plugin.video.youtube, message check_settings
2019-07-19 13:38:25.480 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:25.480 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:25.484 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:25.484 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:25.488 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:25.489 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:25.489 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:25.492 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:25.492 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:25.495 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:25.497 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:25.497 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:25.497 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.access_token) was not found.
2019-07-19 13:38:25.497 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.refresh_token) was not found.
2019-07-19 13:38:25.497 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.access_token.expires) was not found.
2019-07-19 13:38:25.497 T:123145417240576 DEBUG: CSettingsManager: requested setting (youtube.api.last.hash) was not found.
2019-07-19 13:38:25.498 T:123145417240576 DEBUG: [plugin.video.youtube] User: |0| Using API key set: |1|
2019-07-19 13:38:25.502 T:123145426821120 DEBUG: [plugin.video.youtube] onNotification: |check_settings| -> |{"httpd_address": "0.0.0.0", "use_httpd": false, "whitelist": "", "httpd_port": 50152}|
2019-07-19 13:38:25.505 T:123145417240576 DEBUG: [plugin.video.youtube] Starting Kodion framework by bromix...
2019-07-19 13:38:25.506 T:123145417240576 NOTICE: [plugin.video.youtube] Running: YouTube (6.5.0) on Leia (Kodi-18.3) with Python 2.7.15
Params: {}
2019-07-19 13:38:25.506 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:25.506 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:25.509 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:25.510 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:25.510 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:25.517 T:123145417240576 ERROR: [plugin.video.youtube] Mapping for path '/fakeCallToDisplayAWindow' not found
2019-07-19 13:38:25.523 T:123145426284544 DEBUG: Skin Helper Service --> Kodi_Monitor: sender plugin.video.youtube - method: Other.check_settings - data: ["%7B%22httpd_address%22%3A%20%220.0.0.0%22%2C%20%22use_httpd%22%3A%20false%2C%20%22whitelist%22%3A%20%22%22%2C%20%22httpd_port%22%3A%2050152%7D"]
2019-07-19 13:38:25.531 T:4884227520 DEBUG: ------ Window Init (DialogConfirm.xml) ------
2019-07-19 13:38:26.422 T:4884227520 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
2019-07-19 13:38:26.430 T:123145417240576 DEBUG: [plugin.video.youtube] Shutdown of Kodion after |0.9247| seconds
2019-07-19 13:38:26.431 T:123145417240576 INFO: CPythonInvoker(20, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): script successfully run
2019-07-19 13:38:26.931 T:4884227520 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
2019-07-19 13:38:26.931 T:123145425747968 DEBUG: Thread scriptobs 123145425747968 terminating
2019-07-19 13:38:26.931 T:4884227520 DEBUG: WaitOnScriptResult- cancelling plugin YouTube (id=20)
2019-07-19 13:38:26.931 T:123145417240576 DEBUG: onExecutionDone(20, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py)
2019-07-19 13:38:26.942 T:123145417240576 INFO: Python interpreter interrupted by user
2019-07-19 13:38:26.942 T:4884227520 DEBUG: CPythonInvoker(20, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): script termination took 11ms
2019-07-19 13:38:26.942 T:123145417240576 DEBUG: Thread LanguageInvoker 123145417240576 terminating
2019-07-19 13:38:26.942 T:4884227520 DEBUG: StartScript - calling plugin YouTube('plugin://plugin.video.youtube/fakeCallToDisplayAWindow','3','','resume:true')
2019-07-19 13:38:26.943 T:123145417240576 DEBUG: Thread LanguageInvoker start, auto delete: false
2019-07-19 13:38:26.943 T:123145417240576 INFO: initializing python engine.
2019-07-19 13:38:26.943 T:123145417240576 DEBUG: CPythonInvoker(21, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): start processing
2019-07-19 13:38:26.958 T:123145417240576 DEBUG: -->Python Interpreter Initialized<--
2019-07-19 13:38:26.958 T:123145417240576 DEBUG: CPythonInvoker(21, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): the source file to load is "/Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py"
2019-07-19 13:38:26.959 T:123145417240576 DEBUG: CPythonInvoker(21, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): setting the Python path to /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.certifi/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.chardet/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.idna/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.inputstreamhelper/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.kodi-six/libs:/Users/JB/Library/Application Support/Kodi/addons/script.module.requests/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.six/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.urllib3/lib:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/setuptools-18.4-py2.7.egg:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/Pillow-3.0.0-py2.7-macosx-10.14-x86_64.egg:/Applications/Kodi.app/Contents/Libraries:/Applications/Kodi.app/Contents/Libraries/lib/python27.zip:/Applications/Kodi.app/Contents/Libraries/lib/python2.7:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-darwin:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac/lib-scriptpackages:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-tk:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-old:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-dynload
2019-07-19 13:38:26.959 T:123145417240576 DEBUG: CPythonInvoker(21, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): entering source directory /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib
2019-07-19 13:38:26.959 T:123145417240576 DEBUG: CPythonInvoker(21, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): instantiating addon using automatically obtained id of "plugin.video.youtube" dependent on version 2.20.0 of the xbmc.python api
2019-07-19 13:38:26.964 T:123145417777152 DEBUG: Thread scriptobs start, auto delete: false
2019-07-19 13:38:27.165 T:4884227520 DEBUG: ------ Window Init (DialogBusy.xml) ------
2019-07-19 13:38:27.271 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:27.272 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:27.274 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:27.275 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:27.275 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:27.275 T:123145417240576 DEBUG: [plugin.video.youtube] send_notification: |check_settings| -> |{"httpd_address": "0.0.0.0", "use_httpd": false, "whitelist": "", "httpd_port": 50152}|
2019-07-19 13:38:27.276 T:123145417240576 DEBUG: [plugin.video.youtube] JSONStore Load |/Users/JB/Library/Application Support/Kodi/userdata/addon_data/plugin.video.youtube/api_keys.json|
2019-07-19 13:38:27.277 T:123145417240576 DEBUG: [plugin.video.youtube] JSONStore Load |/Users/JB/Library/Application Support/Kodi/userdata/addon_data/plugin.video.youtube/access_manager.json|
2019-07-19 13:38:27.279 T:123145419845632 DEBUG: CAnnouncementManager - Announcement: check_settings from plugin.video.youtube
2019-07-19 13:38:27.279 T:123145419845632 DEBUG: GOT ANNOUNCEMENT, type: 512, from plugin.video.youtube, message check_settings
2019-07-19 13:38:27.282 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:27.282 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:27.284 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:27.286 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:27.286 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:27.288 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:27.288 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:27.290 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:27.292 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:27.292 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:27.294 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:27.294 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:27.297 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:27.298 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:27.298 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:27.301 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:27.301 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:27.303 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:27.305 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:27.305 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:27.305 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.access_token) was not found.
2019-07-19 13:38:27.305 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.refresh_token) was not found.
2019-07-19 13:38:27.305 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.access_token.expires) was not found.
2019-07-19 13:38:27.305 T:123145417240576 DEBUG: CSettingsManager: requested setting (youtube.api.last.hash) was not found.
2019-07-19 13:38:27.306 T:123145417240576 DEBUG: [plugin.video.youtube] User: |0| Using API key set: |1|
2019-07-19 13:38:27.312 T:123145417240576 DEBUG: [plugin.video.youtube] Starting Kodion framework by bromix...
2019-07-19 13:38:27.313 T:123145417240576 NOTICE: [plugin.video.youtube] Running: YouTube (6.5.0) on Leia (Kodi-18.3) with Python 2.7.15
Params: {}
2019-07-19 13:38:27.314 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:27.314 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:27.317 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:27.318 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:27.318 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:27.324 T:123145417240576 ERROR: [plugin.video.youtube] Mapping for path '/fakeCallToDisplayAWindow' not found
2019-07-19 13:38:27.330 T:4884227520 DEBUG: ------ Window Init (DialogConfirm.xml) ------
2019-07-19 13:38:27.344 T:123145426284544 DEBUG: Skin Helper Service --> Kodi_Monitor: sender plugin.video.youtube - method: Other.check_settings - data: ["%7B%22httpd_address%22%3A%20%220.0.0.0%22%2C%20%22use_httpd%22%3A%20false%2C%20%22whitelist%22%3A%20%22%22%2C%20%22httpd_port%22%3A%2050152%7D"]
2019-07-19 13:38:27.371 T:123145426821120 DEBUG: [plugin.video.youtube] onNotification: |check_settings| -> |{"httpd_address": "0.0.0.0", "use_httpd": false, "whitelist": "", "httpd_port": 50152}|
2019-07-19 13:38:28.405 T:4884227520 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
2019-07-19 13:38:28.414 T:123145417240576 DEBUG: [plugin.video.youtube] Shutdown of Kodion after |1.1021| seconds
2019-07-19 13:38:28.416 T:123145417240576 INFO: CPythonInvoker(21, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): script successfully run
2019-07-19 13:38:28.661 T:4884227520 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
2019-07-19 13:38:28.662 T:123145417777152 DEBUG: Thread scriptobs 123145417777152 terminating
2019-07-19 13:38:28.662 T:4884227520 DEBUG: WaitOnScriptResult- cancelling plugin YouTube (id=21)
2019-07-19 13:38:28.662 T:123145417240576 DEBUG: onExecutionDone(21, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py)
2019-07-19 13:38:28.672 T:123145417240576 INFO: Python interpreter interrupted by user
2019-07-19 13:38:28.672 T:4884227520 DEBUG: CPythonInvoker(21, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): script termination took 10ms
2019-07-19 13:38:28.672 T:123145417240576 DEBUG: Thread LanguageInvoker 123145417240576 terminating
2019-07-19 13:38:28.672 T:4884227520 DEBUG: StartScript - calling plugin YouTube('plugin://plugin.video.youtube/fakeCallToDisplayAWindow','4','','resume:true')
2019-07-19 13:38:28.672 T:123145417240576 DEBUG: Thread LanguageInvoker start, auto delete: false
2019-07-19 13:38:28.673 T:123145417240576 INFO: initializing python engine.
2019-07-19 13:38:28.673 T:123145417240576 DEBUG: CPythonInvoker(22, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): start processing
2019-07-19 13:38:28.689 T:123145417240576 DEBUG: -->Python Interpreter Initialized<--
2019-07-19 13:38:28.690 T:123145417240576 DEBUG: CPythonInvoker(22, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): the source file to load is "/Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py"
2019-07-19 13:38:28.690 T:123145417240576 DEBUG: CPythonInvoker(22, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): setting the Python path to /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.certifi/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.chardet/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.idna/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.inputstreamhelper/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.kodi-six/libs:/Users/JB/Library/Application Support/Kodi/addons/script.module.requests/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.six/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.urllib3/lib:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/setuptools-18.4-py2.7.egg:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/Pillow-3.0.0-py2.7-macosx-10.14-x86_64.egg:/Applications/Kodi.app/Contents/Libraries:/Applications/Kodi.app/Contents/Libraries/lib/python27.zip:/Applications/Kodi.app/Contents/Libraries/lib/python2.7:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-darwin:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac/lib-scriptpackages:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-tk:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-old:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-dynload
2019-07-19 13:38:28.690 T:123145417240576 DEBUG: CPythonInvoker(22, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): entering source directory /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib
2019-07-19 13:38:28.690 T:123145417240576 DEBUG: CPythonInvoker(22, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): instantiating addon using automatically obtained id of "plugin.video.youtube" dependent on version 2.20.0 of the xbmc.python api
2019-07-19 13:38:28.693 T:123145417777152 DEBUG: Thread scriptobs start, auto delete: false
2019-07-19 13:38:28.894 T:4884227520 DEBUG: ------ Window Init (DialogBusy.xml) ------
2019-07-19 13:38:29.110 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:29.110 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:29.113 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:29.115 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:29.115 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:29.115 T:123145417240576 DEBUG: [plugin.video.youtube] send_notification: |check_settings| -> |{"httpd_address": "0.0.0.0", "use_httpd": false, "whitelist": "", "httpd_port": 50152}|
2019-07-19 13:38:29.116 T:123145417240576 DEBUG: [plugin.video.youtube] JSONStore Load |/Users/JB/Library/Application Support/Kodi/userdata/addon_data/plugin.video.youtube/api_keys.json|
2019-07-19 13:38:29.116 T:123145417240576 DEBUG: [plugin.video.youtube] JSONStore Load |/Users/JB/Library/Application Support/Kodi/userdata/addon_data/plugin.video.youtube/access_manager.json|
2019-07-19 13:38:29.119 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:29.119 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:29.121 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:29.123 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:29.123 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:29.125 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:29.125 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:29.127 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:29.129 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:29.129 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:29.130 T:123145419845632 DEBUG: CAnnouncementManager - Announcement: check_settings from plugin.video.youtube
2019-07-19 13:38:29.130 T:123145419845632 DEBUG: GOT ANNOUNCEMENT, type: 512, from plugin.video.youtube, message check_settings
2019-07-19 13:38:29.132 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:29.132 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:29.134 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:29.136 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:29.136 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:29.138 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:29.138 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:29.140 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:29.141 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:29.141 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:29.142 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.access_token) was not found.
2019-07-19 13:38:29.142 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.refresh_token) was not found.
2019-07-19 13:38:29.142 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.access_token.expires) was not found.
2019-07-19 13:38:29.142 T:123145417240576 DEBUG: CSettingsManager: requested setting (youtube.api.last.hash) was not found.
2019-07-19 13:38:29.142 T:123145417240576 DEBUG: [plugin.video.youtube] User: |0| Using API key set: |1|
2019-07-19 13:38:29.150 T:123145417240576 DEBUG: [plugin.video.youtube] Starting Kodion framework by bromix...
2019-07-19 13:38:29.150 T:123145417240576 NOTICE: [plugin.video.youtube] Running: YouTube (6.5.0) on Leia (Kodi-18.3) with Python 2.7.15
Params: {}
2019-07-19 13:38:29.151 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:29.151 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:29.153 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:29.154 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:29.154 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:29.160 T:123145417240576 ERROR: [plugin.video.youtube] Mapping for path '/fakeCallToDisplayAWindow' not found
2019-07-19 13:38:29.163 T:4884227520 DEBUG: ------ Window Init (DialogConfirm.xml) ------
2019-07-19 13:38:29.209 T:123145426821120 DEBUG: [plugin.video.youtube] onNotification: |check_settings| -> |{"httpd_address": "0.0.0.0", "use_httpd": false, "whitelist": "", "httpd_port": 50152}|
2019-07-19 13:38:29.211 T:123145426284544 DEBUG: Skin Helper Service --> Kodi_Monitor: sender plugin.video.youtube - method: Other.check_settings - data: ["%7B%22httpd_address%22%3A%20%220.0.0.0%22%2C%20%22use_httpd%22%3A%20false%2C%20%22whitelist%22%3A%20%22%22%2C%20%22httpd_port%22%3A%2050152%7D"]
2019-07-19 13:38:29.857 T:4884227520 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
2019-07-19 13:38:29.866 T:123145417240576 DEBUG: [plugin.video.youtube] Shutdown of Kodion after |0.716| seconds
2019-07-19 13:38:29.867 T:123145417240576 INFO: CPythonInvoker(22, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): script successfully run
2019-07-19 13:38:30.213 T:4884227520 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
2019-07-19 13:38:30.214 T:123145417777152 DEBUG: Thread scriptobs 123145417777152 terminating
2019-07-19 13:38:30.214 T:4884227520 DEBUG: WaitOnScriptResult- cancelling plugin YouTube (id=22)
2019-07-19 13:38:30.214 T:123145417240576 DEBUG: onExecutionDone(22, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py)
2019-07-19 13:38:30.228 T:123145417240576 INFO: Python interpreter interrupted by user
2019-07-19 13:38:30.228 T:4884227520 DEBUG: CPythonInvoker(22, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): script termination took 15ms
2019-07-19 13:38:30.229 T:123145417240576 DEBUG: Thread LanguageInvoker 123145417240576 terminating
2019-07-19 13:38:30.229 T:4884227520 DEBUG: StartScript - calling plugin YouTube('plugin://plugin.video.youtube/fakeCallToDisplayAWindow','5','','resume:true')
2019-07-19 13:38:30.229 T:123145417240576 DEBUG: Thread LanguageInvoker start, auto delete: false
2019-07-19 13:38:30.229 T:123145417240576 INFO: initializing python engine.
2019-07-19 13:38:30.229 T:123145417240576 DEBUG: CPythonInvoker(23, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): start processing
2019-07-19 13:38:30.244 T:123145417240576 DEBUG: -->Python Interpreter Initialized<--
2019-07-19 13:38:30.244 T:123145417240576 DEBUG: CPythonInvoker(23, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): the source file to load is "/Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py"
2019-07-19 13:38:30.245 T:123145417240576 DEBUG: CPythonInvoker(23, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): setting the Python path to /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.certifi/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.chardet/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.idna/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.inputstreamhelper/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.kodi-six/libs:/Users/JB/Library/Application Support/Kodi/addons/script.module.requests/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.six/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.urllib3/lib:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/setuptools-18.4-py2.7.egg:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/Pillow-3.0.0-py2.7-macosx-10.14-x86_64.egg:/Applications/Kodi.app/Contents/Libraries:/Applications/Kodi.app/Contents/Libraries/lib/python27.zip:/Applications/Kodi.app/Contents/Libraries/lib/python2.7:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-darwin:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac/lib-scriptpackages:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-tk:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-old:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-dynload
2019-07-19 13:38:30.245 T:123145417240576 DEBUG: CPythonInvoker(23, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): entering source directory /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib
2019-07-19 13:38:30.245 T:123145417240576 DEBUG: CPythonInvoker(23, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): instantiating addon using automatically obtained id of "plugin.video.youtube" dependent on version 2.20.0 of the xbmc.python api
2019-07-19 13:38:30.250 T:123145417777152 DEBUG: Thread scriptobs start, auto delete: false
2019-07-19 13:38:30.451 T:4884227520 DEBUG: ------ Window Init (DialogBusy.xml) ------
2019-07-19 13:38:30.565 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:30.565 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:30.567 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:30.569 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:30.569 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:30.569 T:123145417240576 DEBUG: [plugin.video.youtube] send_notification: |check_settings| -> |{"httpd_address": "0.0.0.0", "use_httpd": false, "whitelist": "", "httpd_port": 50152}|
2019-07-19 13:38:30.570 T:123145417240576 DEBUG: [plugin.video.youtube] JSONStore Load |/Users/JB/Library/Application Support/Kodi/userdata/addon_data/plugin.video.youtube/api_keys.json|
2019-07-19 13:38:30.570 T:123145417240576 DEBUG: [plugin.video.youtube] JSONStore Load |/Users/JB/Library/Application Support/Kodi/userdata/addon_data/plugin.video.youtube/access_manager.json|
2019-07-19 13:38:30.573 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:30.574 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:30.577 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:30.578 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:30.578 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:30.580 T:123145419845632 DEBUG: CAnnouncementManager - Announcement: check_settings from plugin.video.youtube
2019-07-19 13:38:30.580 T:123145419845632 DEBUG: GOT ANNOUNCEMENT, type: 512, from plugin.video.youtube, message check_settings
2019-07-19 13:38:30.581 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:30.581 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:30.584 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:30.585 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:30.585 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:30.588 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:30.588 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:30.590 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:30.592 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:30.592 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:30.594 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:30.594 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:30.598 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:30.599 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:30.599 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:30.600 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.access_token) was not found.
2019-07-19 13:38:30.600 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.refresh_token) was not found.
2019-07-19 13:38:30.600 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.access_token.expires) was not found.
2019-07-19 13:38:30.600 T:123145417240576 DEBUG: CSettingsManager: requested setting (youtube.api.last.hash) was not found.
2019-07-19 13:38:30.600 T:123145417240576 DEBUG: [plugin.video.youtube] User: |0| Using API key set: |1|
2019-07-19 13:38:30.603 T:123145426821120 DEBUG: [plugin.video.youtube] onNotification: |check_settings| -> |{"httpd_address": "0.0.0.0", "use_httpd": false, "whitelist": "", "httpd_port": 50152}|
2019-07-19 13:38:30.606 T:123145417240576 DEBUG: [plugin.video.youtube] Starting Kodion framework by bromix...
2019-07-19 13:38:30.607 T:123145417240576 NOTICE: [plugin.video.youtube] Running: YouTube (6.5.0) on Leia (Kodi-18.3) with Python 2.7.15
Params: {}
2019-07-19 13:38:30.608 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:30.608 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:30.610 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:30.611 T:123145417240576 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:30.611 T:123145417240576 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:30.618 T:123145417240576 ERROR: [plugin.video.youtube] Mapping for path '/fakeCallToDisplayAWindow' not found
2019-07-19 13:38:30.631 T:4884227520 DEBUG: ------ Window Init (DialogConfirm.xml) ------
2019-07-19 13:38:30.674 T:123145426284544 DEBUG: Skin Helper Service --> Kodi_Monitor: sender plugin.video.youtube - method: Other.check_settings - data: ["%7B%22httpd_address%22%3A%20%220.0.0.0%22%2C%20%22use_httpd%22%3A%20false%2C%20%22whitelist%22%3A%20%22%22%2C%20%22httpd_port%22%3A%2050152%7D"]
2019-07-19 13:38:31.288 T:4884227520 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
2019-07-19 13:38:31.298 T:123145417240576 DEBUG: [plugin.video.youtube] Shutdown of Kodion after |0.6922| seconds
2019-07-19 13:38:31.300 T:123145417240576 INFO: CPythonInvoker(23, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): script successfully run
2019-07-19 13:38:31.934 T:123145415016448 DEBUG: Thread JobWorker 123145415016448 terminating (autodelete)
2019-07-19 13:38:31.949 T:123145416167424 DEBUG: Thread JobWorker 123145416167424 terminating (autodelete)
2019-07-19 13:38:31.951 T:123145418772480 DEBUG: Thread JobWorker 123145418772480 terminating (autodelete)
2019-07-19 13:38:31.954 T:123145415553024 DEBUG: Thread JobWorker 123145415553024 terminating (autodelete)
2019-07-19 13:38:31.964 T:4884227520 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
2019-07-19 13:38:31.964 T:123145417777152 DEBUG: Thread scriptobs 123145417777152 terminating
2019-07-19 13:38:31.964 T:4884227520 DEBUG: WaitOnScriptResult- cancelling plugin YouTube (id=23)
2019-07-19 13:38:31.965 T:123145417240576 DEBUG: onExecutionDone(23, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py)
2019-07-19 13:38:31.977 T:123145417240576 INFO: Python interpreter interrupted by user
2019-07-19 13:38:31.977 T:4884227520 DEBUG: CPythonInvoker(23, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): script termination took 12ms
2019-07-19 13:38:31.977 T:123145417240576 DEBUG: Thread LanguageInvoker 123145417240576 terminating
2019-07-19 13:38:31.977 T:4884227520 DEBUG: StartScript - calling plugin YouTube('plugin://plugin.video.youtube/fakeCallToDisplayAWindow','6','','resume:false')
2019-07-19 13:38:31.978 T:123145415016448 DEBUG: Thread LanguageInvoker start, auto delete: false
2019-07-19 13:38:31.978 T:123145415016448 INFO: initializing python engine.
2019-07-19 13:38:31.978 T:123145415016448 DEBUG: CPythonInvoker(24, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): start processing
2019-07-19 13:38:31.992 T:123145415016448 DEBUG: -->Python Interpreter Initialized<--
2019-07-19 13:38:31.993 T:123145415016448 DEBUG: CPythonInvoker(24, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): the source file to load is "/Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py"
2019-07-19 13:38:31.993 T:123145415016448 DEBUG: CPythonInvoker(24, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): setting the Python path to /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.certifi/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.chardet/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.idna/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.inputstreamhelper/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.kodi-six/libs:/Users/JB/Library/Application Support/Kodi/addons/script.module.requests/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.six/lib:/Users/JB/Library/Application Support/Kodi/addons/script.module.urllib3/lib:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/setuptools-18.4-py2.7.egg:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages/Pillow-3.0.0-py2.7-macosx-10.14-x86_64.egg:/Applications/Kodi.app/Contents/Libraries:/Applications/Kodi.app/Contents/Libraries/lib/python27.zip:/Applications/Kodi.app/Contents/Libraries/lib/python2.7:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/site-packages:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-darwin:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/plat-mac/lib-scriptpackages:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-tk:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-old:/Applications/Kodi.app/Contents/Libraries/lib/python2.7/lib-dynload
2019-07-19 13:38:31.993 T:123145415016448 DEBUG: CPythonInvoker(24, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): entering source directory /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib
2019-07-19 13:38:31.993 T:123145415016448 DEBUG: CPythonInvoker(24, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): instantiating addon using automatically obtained id of "plugin.video.youtube" dependent on version 2.20.0 of the xbmc.python api
2019-07-19 13:38:31.998 T:123145415553024 DEBUG: Thread scriptobs start, auto delete: false
2019-07-19 13:38:32.199 T:4884227520 DEBUG: ------ Window Init (DialogBusy.xml) ------
2019-07-19 13:38:32.304 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:32.304 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:32.307 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:32.308 T:123145415016448 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:32.308 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:32.308 T:123145415016448 DEBUG: [plugin.video.youtube] send_notification: |check_settings| -> |{"httpd_address": "0.0.0.0", "use_httpd": false, "whitelist": "", "httpd_port": 50152}|
2019-07-19 13:38:32.309 T:123145415016448 DEBUG: [plugin.video.youtube] JSONStore Load |/Users/JB/Library/Application Support/Kodi/userdata/addon_data/plugin.video.youtube/api_keys.json|
2019-07-19 13:38:32.309 T:123145415016448 DEBUG: [plugin.video.youtube] JSONStore Load |/Users/JB/Library/Application Support/Kodi/userdata/addon_data/plugin.video.youtube/access_manager.json|
2019-07-19 13:38:32.312 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:32.312 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:32.313 T:123145419845632 DEBUG: CAnnouncementManager - Announcement: check_settings from plugin.video.youtube
2019-07-19 13:38:32.313 T:123145419845632 DEBUG: GOT ANNOUNCEMENT, type: 512, from plugin.video.youtube, message check_settings
2019-07-19 13:38:32.315 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:32.316 T:123145415016448 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:32.316 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:32.319 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:32.319 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:32.322 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:32.323 T:123145415016448 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:32.323 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:32.325 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:32.325 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:32.328 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:32.329 T:123145415016448 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:32.329 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:32.332 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:32.332 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:32.335 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:32.336 T:123145415016448 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:32.336 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:32.336 T:123145415016448 DEBUG: CSettingsManager: requested setting (kodion.access_token) was not found.
2019-07-19 13:38:32.336 T:123145415016448 DEBUG: CSettingsManager: requested setting (kodion.refresh_token) was not found.
2019-07-19 13:38:32.337 T:123145415016448 DEBUG: CSettingsManager: requested setting (kodion.access_token.expires) was not found.
2019-07-19 13:38:32.337 T:123145415016448 DEBUG: CSettingsManager: requested setting (youtube.api.last.hash) was not found.
2019-07-19 13:38:32.337 T:123145415016448 DEBUG: [plugin.video.youtube] User: |0| Using API key set: |1|
2019-07-19 13:38:32.343 T:123145415016448 DEBUG: [plugin.video.youtube] Starting Kodion framework by bromix...
2019-07-19 13:38:32.344 T:123145415016448 NOTICE: [plugin.video.youtube] Running: YouTube (6.5.0) on Leia (Kodi-18.3) with Python 2.7.15
Params: {}
2019-07-19 13:38:32.344 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-07-19 13:38:32.344 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format...
2019-07-19 13:38:32.347 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-07-19 13:38:32.349 T:123145415016448 DEBUG: CSettingsManager: requested setting (kodion.mpd.webm) was not found.
2019-07-19 13:38:32.349 T:123145415016448 DEBUG: CAddonSettings[plugin.video.youtube]: failed to find definition for setting kodion.mpd.webm. Creating a setting on-the-fly...
2019-07-19 13:38:32.356 T:123145415016448 ERROR: [plugin.video.youtube] Mapping for path '/fakeCallToDisplayAWindow' not found
2019-07-19 13:38:32.356 T:123145426284544 DEBUG: Skin Helper Service --> Kodi_Monitor: sender plugin.video.youtube - method: Other.check_settings - data: ["%7B%22httpd_address%22%3A%20%220.0.0.0%22%2C%20%22use_httpd%22%3A%20false%2C%20%22whitelist%22%3A%20%22%22%2C%20%22httpd_port%22%3A%2050152%7D"]
2019-07-19 13:38:32.364 T:4884227520 DEBUG: ------ Window Init (DialogConfirm.xml) ------
2019-07-19 13:38:32.379 T:123145426821120 DEBUG: [plugin.video.youtube] onNotification: |check_settings| -> |{"httpd_address": "0.0.0.0", "use_httpd": false, "whitelist": "", "httpd_port": 50152}|
2019-07-19 13:38:33.323 T:4884227520 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
2019-07-19 13:38:33.329 T:123145415016448 DEBUG: [plugin.video.youtube] Shutdown of Kodion after |0.9864| seconds
2019-07-19 13:38:33.330 T:123145415016448 INFO: CPythonInvoker(24, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): script successfully run
2019-07-19 13:38:33.899 T:4884227520 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
2019-07-19 13:38:33.899 T:123145415553024 DEBUG: Thread scriptobs 123145415553024 terminating
2019-07-19 13:38:33.899 T:4884227520 DEBUG: WaitOnScriptResult- cancelling plugin YouTube (id=24)
2019-07-19 13:38:33.900 T:123145415016448 DEBUG: onExecutionDone(24, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py)
2019-07-19 13:38:33.911 T:123145415016448 INFO: Python interpreter interrupted by user
2019-07-19 13:38:33.911 T:4884227520 DEBUG: CPythonInvoker(24, /Users/JB/Library/Application Support/Kodi/addons/plugin.video.youtube/resources/lib/default.py): script termination took 11ms
2019-07-19 13:38:33.911 T:123145415016448 DEBUG: Thread LanguageInvoker 123145415016448 terminating
2019-07-19 13:38:35.498 T:4884227520 DEBUG: Keyboard: scancode: 0x00, sym: 0x0136, unicode: 0x0000, modifier: 0x0
2019-07-19 13:38:35.498 T:4884227520 DEBUG: GetActionCode: Trying Hardy keycode for 0xf200
2019-07-19 13:38:35.498 T:4884227520 DEBUG: Previous line repeats 3 times.
2019-07-19 13:38:35.498 T:4884227520 DEBUG: HandleKey: 0 (0xf200, obc-61697) pressed, action is
2019-07-19 13:38:36.186 T:4884227520 DEBUG: Keyboard: scancode: 0x00, sym: 0x0136, unicode: 0x0000, modifier: 0x0
### Screenshots
Here are some links or screenshots to help explain the problem:
https://youtu.be/9RouKkhaDqk
### Your Environment
Used Operating system:
- [X] OSX
- [ ] Android
- [ ] iOS
- [ ] Linux
- [] Raspberry-Pi
- [ ] Windows
- [ ] Windows UWP
- Operating system version/name:
- Kodi version:
18.3 / Git:20190619-89472b7d69
*note: Once the issue is made we require you to update it with new information or Kodi versions should that be required.
Team Kodi will consider your problem report however, we will not make any promises the problem will be solved.*
