Hey, I am currently running the lastest version of osmc on a raspberry pi 3. I enabled CEC and everything works fine so far, but ~2 minutes after I shutdown my TV it turns back on. I was able to determine, that it is indeed the raspberry, that it causing the TV to power back on. In other words: disabling CEC via system-> input-> CEC Adapter solved the problem.
Is there a way to prevent any “power on” signal to be sent by the raspberry ? Thanks in advance.
