Problem playing music stream [SOLVED]
I am trying to play this music stream from Radionomy:
http://listen.radionomy.com/rockshow-classic-
The stream does not play (instead it plays on VLC) and here is the log: http://paste.osmc.io/nonepilehe.vhdl
Other streams from the same site are working.
For example: http://listen.radionomy.com/rockshowlive
According to VLC, both streams are:
Codec: MPEG Audio layer 1/2 (mpga)
Channels: Stereo
Sample rate: 44100 Hz
Bitrate: 128 kb/s
Can someone try to play “rockshow-classic-” or can help me?
Thank you.
EDIT:
Solved adding .m3u at the end of url: http://listen.radionomy.com/rockshow-classic-.m3u
I don’t know why, but it worked! :wink:
