Problem with DV profile 5 and update after it
Hello , had problem with dv profile 5(black screen).installed grahamh update from similar topic ( https://discourse.osmc.tv/t/dv-profile-5-shows-white-screen-on-one-show-only/112548/14?u=kinokot ) .Profile 5 now plays right colors but when inside playing any video i press pop up menu , film and the menu starts freezing and plays very slowly. To solve the issue i have to go to settings inside movie and press video calibration. after completing calibration everything works like it should .
Also noticed when i wanted to write logs and restarted vero v twice . Every time first start of the fel movie had wrong colors . And after second start colors become fine . It is also inside logs. So two issues.
Here my logs:
https://paste.osmc.tv/ayinalahix
If you’re using the development repostiory you could wait for a new update which should arrive shortly or you could reinstall OSMC.
so if i go back , i will have problems with profile 5 or i have problems now with glitchy menu if i stay , right ?
Until there’s a further update, yes.
I am not fully aware of the P5 problems, but if they’re fixed in staging that’s a good sign.
Thanks .
How to switch back to normal releases from development repository for future updates ?
The clean way is to reinstall OSMC from scratch with the release image as Sam already suggested.
I mean , i dont want to go back because dv p5 is important for me , but i want to get future updates from stable updates repository not dev repository . How to switch back to normal repository future updates without reinstalling osmc .
Read again the instructions in the quoted link from grahamh in you initial post. The relevant apt source will be automatically removed after 14 days or you can remove manually on an earlier date.
Ok , thanks for the answer . So is there a difference between if i upgrade future update from this dev build i have now or if i make a clean osmc reinstall before installing new stable build . I can do clean reinstall if it is needed but dont want to install everything again on my vero v because as i understand correctly osmc backup only have settings backup inside , but doesn’t save plugins like plexkodiconnect in backup
No difference
For what it’s worth, I hope to update Kodi over the weekend with Graham’s fix for this.
In your situation, I’d just wait. But that weekend fix is not guaranteed. There’s something I’m still working out. With that said, I obviously intend to get this fixed ASAP
If this happens, it’s usually just that the colours are a bit ‘washed out’. Is that what you are seeing? We haven’t yet found out why it happens. But I haven’t asked Claude yet :stuck_out_tongue:
Yes exactly . Also noticed yesterday on last devs build that dv p5 had strange behavior. It changed colors from cold to warm and from warm to cold every minute or so . It is not so noticeable, but if you see it then you will see it every time. If needed , i can post log with this problem .
Just wait - we know what the issue is and this should be solved shortly
Any news about the update ?
Once I have some news, I’ll let you know.
