Problem with external drive
Hello! I have an external hard drive connected to my windows pc.
How can I access that external drive on my raspberry pi which runs the latest version of Kodi?
http://kodi.wiki/view/SMB/Windows
I have tried but with no success
What didn’t work?
When I follow the guide listed, the problem is not sovled. It seems like the kodi software wont detect the smb shares in the workgroup?
Add by IP directly
Tried too, but if I try to add it by ip (assuming it is done this way: smb:\x.x.x.x?)
I solved it. The solution was as easy as, when I tried to add it as SMB, I had to create a password for my account on the pc(Set up a password, which I did not have) and it solved the problem like a charm, now i works!
