Hello
After change of router and restart of raspberry I can´t see in Main menu Television item.
However I can login to tvheadend over web pages and I can program for recording any movie over web interface, but I can´t programing anything over HTSP interface.
Do you have some idea how to repair it?
My logs is here. http://paste.osmc.tv/iyelofomuv
Raspberry Pi3, Noobs, OSMC last version
This IP is correct. Its my RPi3.
Which banned addon you mean?
Actually I have installed only Youtube and NASA addon from Kodi repository and a few plugins from Kodi CZ SK Repository.
Jan
Ok
It was helped
After a few restart and kodi freezing now the htsp interface running. No any reconfiguration was necessary.
The file TV29.db is a file for TVH or HTSP? Just for increasing of my knowlegdes.
While I do understand that you trying to avoid any connection with piracy I do think that refusing to help people just because they have a “bad” addon installed ( and they are not even seeking help for that addon ) is a bit backwards to not say something worse specially considering kodi and vero are aimed at playing media in file format… which you know as well as I do basically means that people would need to rip their own discs. Wich can be done with apps that are pretty gray area because they remove encryption and are meant for making “personal backups” (haha good joke). And even if I want to play the media I bought off itunes I can’t play it on vero without removing DRM and the app to do so is very ilegal.
I know you didn’t come up with the rules but it seems a bit backwards considering the circumstances
And just where did I refuse to help him? In fact I solved his problem for him! And those ‘bad’ addons are know to cause problems with the system overall, so requesting that he clean them up is perfectly legitimate.
If you mean **** - I have no any addons installed from this repo.
Anyway I already deleted this repository from my sources.xml.
Thanks again for your help
Jan
I´m little bit feeling like in the world of Harry Potter - “He who must not be named”
I removed all my video addons - including Youtube and NASA from Kodi repository, because you did not wrote the name of blacklisted addon and again - all of my addons was installed from Kodi Repository and repository with czech addons
The truth is, that I have from history in sources.xml some banned repository - but all of my installed addons was installed from different repository - I used this repository in the past for some testing, because there was some old version of addons from Kodi CZ SK repo.
I very much appreciate the hard work of the entire OSMC team - that’s why I use OSMC, but some things are hard to understand for me.
