Hello (sorry for my english, i’m french)
I have an raspberry pi 3 running OSMC. I use it like a mediace center oubf course and an FTP server and a NAS with samba. I had learn todo that with tutorial and I sucess to make it, with an external HDD USB. (model : TOURO S)
After few month I buy a second HDD (almost the same as the first, just the RPM are different ; model : TOURO S mobile) to make back-up with rsync and crontab. I had many problem to power them because of the power supply and th fuse of the pi. Finaly i decided to buy an powered USB hub with 4 usb ports. No more problem with the powering but…
When I mount them manually, there is no problem but with the fstab each time I reboot the pi, the second HDD isn’t mount.
I try with /dev/sd** and the UUID, it is the same result.
osmc@raspberrypi:~$ mount
devtmpfs on /dev type devtmpfs (rw,relatime,size=370520k,nr_inodes=92630,mode=75 5)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
tmpfs on /run type tmpfs (rw,relatime)
/dev/mmcblk0p2 on / type ext4 (rw,relatime,stripe=1024,data=ordered)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmod e=000)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xa ttr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatim e,cpu,cpuacct)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blki o)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,mem ory)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,de vices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,fr eezer)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,ne t_cls)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=22,pgrp=1,time out=300,minproto=5,maxproto=5,direct)
mqueue on /dev/mqueue type mqueue (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
systemd-1 on /boot type autofs (rw,relatime,fd=33,pgrp=1,timeout=300,minproto=5, maxproto=5,direct)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
/dev/sdb1 on /media/NAS type fuseblk (rw,noatime,user_id=0,group_id=0,allow_othe r,blksize=4096)
/dev/sda2 on /media/TOURO Mobile USB3.0 type fuseblk (rw,nosuid,nodev,relatime,u ser_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks)
/dev/mmcblk0p1 on /boot type vfat (rw,noatime,fmask=0022,dmask=0022,codepage=437 ,iocharset=ascii,shortname=mixed,errors=remount-ro)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=75104k,mode=70
“/dev/sdb1 on /media/NAS” show that it’s OK for the first HDD and " /dev/sda2 on /media/TOURO Mobile USB3.0" show that it don’t sucess to mount to the forlder /media/backup
osmc@raspberrypi:~$ sudo blkid
/dev/mmcblk0: PTUUID=“a0d13c40” PTTYPE=“dos”
/dev/mmcblk0p1: UUID=“9345-7DA2” TYPE=“vfat” PARTUUID=“a0d13c40-01”
/dev/mmcblk0p2: UUID=“4bb0e73c-aa63-4b2b-bdbb-13fc5b0fde42” TYPE=“ext4” PARTUUID=“a0d13c40-02”
/dev/sda1: PARTLABEL=“Microsoft reserved partition” PARTUUID=“0644328d-98fc-401a-9692-30afa1c37346”
/dev/sda2: LABEL=“TOURO Mobile USB3.0” UUID=“805684F25684E9EC” TYPE=“ntfs” PARTLABEL=“Basic data partition” PARTUUID=“53d93b49-6b5e-44d4-9a4a-b6d671755231”
/dev/sdb1: LABEL=“TOURO S” UUID=“B866A77366A73154” TYPE=“ntfs” PARTUUID=“d232d213-01”
Here me fstab file :
/dev/mmcblk0p1 /boot vfat defaults,noatime,noauto,x-systemd.automount 0 0
UUID=“B866A77366A73154” /media/NAS auto noatime,nofail 0 0
UUID=“805684F25684E9EC” /media/backup auto noatime,nofail 0 0
I need some help please !
