hope my english is good enough to describe my problem.
First - I have:
1 NAS
2 Raspberry Pi Model 1 B
1 Raspberry Pi Model 2
all connected by LAN
Now this year, when I got the new Raspberry Pi 2, I used to listen to the suggestion of people to use the new OSMC with Kodi to stream my movies (*.ISO, *.IMG (DVD5 & DVD9) as well as *.MKV) from NAS.
Before, I was using RASPBMC and Kodi and I seldom got problems.
Because of the Model 2 I wanted to try OSMC and it worked - for first.
Playing Movie from regular hard disk drive does not make any problem, even I use BluRay.quality movies.
Now when I try any kind of Movie from the NAS, it takes several minutes, then there is a time shift between the picture and the voice.
on my old Raspberry I went back to the RASPBMC with XBMC. And there is no problem. If I use OSMC + Kodi, I have the same negative effect on my older Raspberry.
So my Question is - if there is any kind of setting I should use or maybe any special version I can use for not to see this problem.
im reading this right? you want play image files (*.img, *.iso) as movie? is this even possible? … try copy some movie from the mentioned harddrive to your NAS and you will see…
video formats are *.avi, *.mkv, *.mp4 and so… as i know files like *.img, *.iso are used for software/os images, not movie images…
So, after long time searching, do the trial and error through all the settings I definetly found the mistake with one or more wrong settings.
Still I am not sure, which setting was wrong, because I’ve changed several at one time.
Not very scientific, but it worked.
