Problem with Pvr IPTV simple
Hello, I currently have a problem with OSMC.
When I watch an IPTV stream with PVR IPTV SIMPLE, the software goes out and returns to the menu.
I want to know how to solve the problem. Stream works fine with VLC on my computer
Thank you for the help you can give me.
Logs please
I have the same problem since my units updated to Kodi 16 today. I am running an old HDHR-US. I just read that the guys at KODI removed support for the strm files I used for these units. Do you guys have any plan to add this back into your version?
Where the logs is it ? i’m new in raspberry pi.
.kodi/temp/kodi.log
For uploading there is a build in uploader at MyOSMC or from command line grab-logs -A
I have upload my logs on pastebin
Did it ever work on the raspberry before?
OSMC work very fine on movies or other video on my NAS and my problem is only with pvr iptv simple addon for live TV my streaming link are OK on my computer with VLC program and this is not the case with OSMC.
I have solve my problem thank for help =)
Would be great if you summarise how your solved your problem to help others.
I have Buy license MPG-2 for Raspberry pi and its ok now
Hello! I can’t install pvr.iptvsimple, do you know what need adiicionaly to install?
22:16:20 3248.424805 T:1733293040 ERROR: Unable to load /home/osmc/.kodi/addons/pvr.iptvsimple/pvr.iptvsimple.so.2.0.0, reason: /home/osmc/.kodi/addons/pvr.iptvsimple/pvr.iptvsimple.so.2.0.0: wrong ELF class: ELFCLASS64
22:16:20 3248.427002 T:1733293040 WARNING: UpdateAndInitialiseClients - failed to create add-on PVR IPTV Simple Client, status = 6
22:16:20 3248.427246 T:1733293040 WARNING: UpdateAndInitialiseClients - failed to load the dll for add-on PVR IPTV Simple Client, disabling it
