Problems continuing movie
I have a Problem with continuing some Movie Files.
I am watching a Movie and if i Stop this Movie and try to continue the next day it doesnt work. I see the wait symbol (blue circle) and nothing happens. if I manually rewind to this point I get the same result.
Thanks for every Support.
Shawn26
Infos:
  • all Files are in my NAS
  • KODI DB also on my NAS (SQL DB)
So, in summary:
  • activate the logging
  • reboot the OSMC device
  • upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Regards Tom.
Everything is ok now. It was a Problem with the Movie file.
Thanks everybody.
